argg!! Wheel weight question (lead weights)
Old Aug 30, 2008 | 02:19 PM
SRTtoZ's Avatar
SRTtoZ
Default argg!! Wheel weight question (lead weights)
Im talking about the weights they use to Balance...
I bought a set of LMGT4's with tires pre mounted/balanced.
Anyway opened up the rims today and they are gorgeous...but one of the weights was loose.
2 of the wheels have (4) Lead square weights in them.
1 of the wheels has (5) lead square weights
1 of the wheels has (1) BIGGER lead square
and then a Square bar of (4) weights fell out of the box...
No clue where this was mounted on the rim.
So what do I have to do to have this corrected? bring it in and rebalance?
Old Aug 30, 2008 | 02:27 PM
SRTtoZ's Avatar
SRTtoZ
also, I can bring in the 1 wheel where the weight fell off, correct?
Old Aug 30, 2008 | 02:30 PM
If you are uncertain about balance, have them balanced before installing.
Old Aug 30, 2008 | 02:41 PM
Spike100's Avatar
Spike100
I agree with David. You should have the wheels re-balanced if there is any question (and… weights that are “falling-off” is an indication that it is certainly wise to check the individual wheel/tire balancing).
BTW: Lead weights are now environment-unfriendly.
--Spike
Old Aug 30, 2008 | 03:03 PM
SRTtoZ's Avatar
SRTtoZ
Ok thanks,
Is it a problem if I put the weights into my mouth to clean them off after they fell off?
Old Aug 30, 2008 | 03:06 PM
Spike100's Avatar
Spike100
^^ If that is what you want to do... then go ahead.
Old Aug 30, 2008 | 04:17 PM
mariar508's Avatar
mariar508
Originally Posted by SRTtoZ
Ok thanks,
no its not a problem, they just found out lead in not toxic
Old Sep 2, 2008 | 03:30 AM
Z04's Avatar
Z04
i would have them rebalanced anyway.
Old Sep 2, 2008 | 04:28 AM
terrasmak's Avatar
So whats the turnout, all good now??
Old Sep 2, 2008 | 08:55 AM
SRTtoZ's Avatar
SRTtoZ
Well I will bring them to get them balanced again.
I didnt do it yet because im still waiting for my Nismo Lugs from mynismo.com
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
Shane86
Sep 17, 2015 05:33 PM
torchkc
Sep 11, 2015 08:26 PM
