HUMMING NOISES
Old Oct 19, 2008 | 08:23 AM
DEVILS's Avatar
DEVILS
Default HUMMING NOISES
I JUST BOUGHT MY 2003 Z ABOUT 1 MONTH AGO IT HAS TWO DIFFERENT BRAND OF TIRES ON IT. I WANTED TO KNOW IF THAT WAS THE REASON FOR THE HUMMING AND WHAT ARE GOOD ALL SEASON TIRES TO PUT ON IT. THANKS
Old Oct 19, 2008 | 08:29 AM
tranceformer95's Avatar
tranceformer95
MAYBE.
It depends on the tire and how worn they are. What brand/model tires do you have?
Old Oct 19, 2008 | 08:35 AM
LeMans 05's Avatar
LeMans 05
Why are you yelling?
Old Oct 21, 2008 | 02:54 PM
Welcome. Some tires are more noisy than others. Nothing wrong with the tires they are just noisy.
Old Oct 21, 2008 | 03:14 PM
vnarang's Avatar
vnarang
Lol, why do you think he's yelling?
Old Oct 21, 2008 | 04:31 PM
THe Emperor's Avatar
THe Emperor
Because typing in all caps indicates that a person is yelling.
Old Oct 22, 2008 | 05:06 AM
sam2944's Avatar
sam2944
This is due to "scalonated" tires. Is a type of wearing type on directional tires. You can confirm it by lifting the car and manually turn the wheel, you will see "steps" in the thread area. No solution, just new tires or select a non-directional tire. (even used)
Old Oct 22, 2008 | 07:18 AM
cheshirecat79's Avatar
cheshirecat79
Sounds like you're describing tire feathering, which was an issue on 2003 z's. The "roaring" between 15-30 miles an hour can be fixed with an alignment. If the inside of your tire is destroyed as a result of the feathering, you can take it somewhere and have them swap the tires so that the feathered part is on the outside if you want to get a little more life out of the tires.
Old Oct 22, 2008 | 09:55 AM
Thermal1's Avatar
Thermal1
WHAT? I CAN'T HEAR YOU OVER THE HUMMING SOUND YOUR TIRES MAKE
Old Oct 22, 2008 | 04:21 PM
Jimmy Mack's Avatar
Jimmy Mack
I am wondering if there is any truth that if you replace the control arms with after market ones that have more adjustment,that will resolved the feathering problem ?
Old Oct 22, 2008 | 04:24 PM
Jimmy Mack's Avatar
Jimmy Mack
Also is Nissan being pressured into a recall campaign to fix the problem at their expense as was done with 84,85,86, 300 injector recall ?
Old Oct 22, 2008 | 05:01 PM
Spike100's Avatar
Spike100
Do you hear the humming noise more when you slowdown, or does the humming noise become more pronounced as your speed increases?
If the humming noise is greater as you slow the car, it might be the “feathering problem.” That is a common problem with '03 models (as you own), but, this would be more a “roar” than a “humming” noise.
If the humming noise is there all the time (and maybe a little greater as you increase your speed), it’s probably the tire and its tread design. Generally tires with more stiff sidewalls may make more noise, but that isn’t true in all cases. Tire noise also differs depending upon the tread, tire compound-makeup, and even the tire manufacturer. For example, Michelin tires run very quiet, and Avon tires make a lot of noise.
The best comment on this tread:
Also… you might want to turn-off your all-caps key. “All-caps” is difficult to read.
--Spike
Old Oct 23, 2008 | 12:48 PM
J's 350z!'s Avatar
J's 350z!
My car is like this too I have a set of Falken tires and my back tires are a little more wider and samething happens. I get a humming noise,its just the tires
Old Oct 24, 2008 | 02:30 PM
Always happy to help. If you have other questions please don't hesitate to waste my time.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
