Wheel Spacer and Fender Rolling
1: Why don't fenders come rolled from the factory, I mean isn't it there for a reason (helps the structural integrity of the fender frame).
2.I am thinking of getting the Ichiba Version II Bolt-On Aluminum Spacers, are they a good brand......And finally they say they are bolt on, are bolt-on's just as safe the regular deal?
1) Actually, the front fender are rolled on the Z. It's only the rears that are unrolled. An unrolled edge is stronger since the metal is formed in an "L" shape. When you roll it, you create a "U" shape so there's not as much metal perpendicular to the body surface to stiffen it.
2) I'd guess they're as safe as any other spacer as long as you check the nuts occasionally to make sure they don't work loose. I know somebody (not a 350Z) that lost a wheel due to an improperly installed spacer. I'm sure there are people who've lost wheels due to improperly tightened lug nuts so just about anything can happen.
Any reason you want the bolt on vs. the bolt through? Other than not having to change studs to something longer?
Arguably so, and it's impossible to check the tightness of the nuts holding the
spacer to the hub without taking your wheel off. If it's only a dd/street car I wouldn't
worry about it.
worry about it.
Obviously the front wheels can turn, requiring adequate clearance; but I wouldn't think that is a factor here (rolled-fender-lips).
This is a question... I don't have an answer but would like to learn.
--Spike
Dave, I wonder why the front fenders are rolled, and the rears or not. I understand your point about rigidity, but also wonder why this differs front to rear.
--Spike
--Spike
