235/40/18 front 275/35/18 rear on stock rims
Old Dec 2, 2008 | 03:20 PM
baspence's Avatar
baspence
Default 235/40/18 front 275/35/18 rear on stock rims
as the title of thread, what do you guys think? it's time for some new rubber so I'm definately getting the kdw2's. just trying to figure out what sizes I want to get. I want more grip out back so I can shift hard and not get sideways the whole time but I also want to maintain turning ability. are the size differences too much from front to back? the height of the tires should be close but I know that's a pretty big difference in the widths.
Old Dec 2, 2008 | 03:24 PM
scotts300's Avatar
scotts300
Is that on 8" fronts and 8.5" rears?
Old Dec 2, 2008 | 03:29 PM
baspence's Avatar
baspence
yes sir, stock
Old Dec 2, 2008 | 04:57 PM
terrasmak's Avatar
Lets see, first your car will handle worse with the extra stagger in width. Second the rear tire width you selected is to wide for the wheel, and will roll a little on the wheel, during a high corner load.
I suggest 245/40 front and 245/45 rear, if you have to have a wider rear tire, get a 255/40 rear tire.
Old Dec 2, 2008 | 05:05 PM
The wheel is 215.8mm wide.
The tire is 275 mm wide.
Think about it.
Old Dec 2, 2008 | 07:04 PM
baspence's Avatar
baspence
I've got 255's on the back right now.
Old Dec 3, 2008 | 04:42 AM
Beau's Avatar
Beau
In my experience, 350Z's with STOCK suspension, handle best with a square setup. If you can't afford new wheels to get wider tires then get the stickiest tires you can afford.
Again, in my EXPERIENCE, the Kumho XS's are excellent tires. Given, I've only experienced a few tires. But, I've tracked 3 models, Nexen N3000, Kumho MX, and Kumho XS.
Nexen's: Great cheap tire actually. Highly recommend for a kick around street tire. My instructors at the track even commented on how good they were and said they felt better than the Yokahama AVS ES100's for comparison. But, they weren't driving.
MX's: First real tire. Much stickier than the Nexens. My straight away speeds increased a bit because my exit speeds were so much higher. My shift points on the track were earlier than before.
XS's: (given, I switched from 225's to 275's) Incredible difference! Much higher corner speeds.
Old Dec 3, 2008 | 08:27 AM
lowrider's Avatar
lowrider
For the stock 8.0/ 8.5" combo. The best size combination to maintain the stagger, and still fit your wheels is 245/40/18 front and 265/40/18 in back. With the 8.5" wheel, I would go no wider in back. IMHO, maintain the stock stagger in our vehicles.
Lou
Old Dec 3, 2008 | 10:30 AM
scotts300's Avatar
scotts300
245 or 255 front - max. 255 or 265 rear - max. Make sure you get the profiles correct though.
Old Dec 3, 2008 | 11:52 AM
baspence's Avatar
baspence
thanks guyz
Old Dec 11, 2008 | 09:26 PM
Raceism's Avatar
Raceism
Anyone know the offset of '03 Track rims?
Old Dec 11, 2008 | 10:20 PM
TCO's Avatar
TCO
front 8j18et30 ... rear 8,5j18et33
Old Dec 12, 2008 | 05:15 AM
z-u-later's Avatar
z-u-later
Same as '06+ rims -- +30F, +33R
m_0g
Jun 3, 2021 10:05 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
hardkicks
Sep 20, 2015 12:28 PM
