Wheel spacer
Old Dec 16, 2008 | 10:02 AM
spinviper's Avatar
spinviper
Default Wheel spacer
I am owner 06 350Z Track. I feel the stock rims is go a little inside the fender. So I want to put a wheel spacer on it, make it a littler wider but not too wide.
I dont know what size of wheel spacer whould i go with ? 15 mm 20 mm ?
Thank you
Old Dec 16, 2008 | 10:16 AM
zete350's Avatar
zete350
Depends on your own preference...how much you want to push out the wheels. I've seen people do 20mm in the front and 25mm in the back and it's looks pretty nice.
Old Dec 16, 2008 | 10:30 AM
How far do you want to move the wheels?
Old Dec 16, 2008 | 10:47 AM
Black Z Eddie's Avatar
Black Z Eddie
https://my350z.com/forum/southern-ca...ml#post6680674
Old Dec 16, 2008 | 03:41 PM
spinviper's Avatar
spinviper
Thank every one. I decided to go with 20 Front 25 Rear.
Old Dec 16, 2008 | 06:45 PM
chicagokid's Avatar
chicagokid
Are you using 18" or 19" wheels??
Old Dec 16, 2008 | 06:48 PM
That'll work.
Old Dec 16, 2008 | 08:23 PM
z-u-later's Avatar
z-u-later
25mm front / 30mm rear will be more flushed. Trust me.
Old Dec 16, 2008 | 08:26 PM
JasonZ-YA's Avatar
JasonZ-YA
yes! you should see that...........where is Nihsnek? he has that set up...
-j
Old Dec 16, 2008 | 08:27 PM
Nihsnek's Avatar
Nihsnek
Sic 'Em
This is ideal for track wheels, it will make it look very clean and flush. I had 15mm all around...not enough. I recently put 25mm/30mm on and it looks damn sexy.
I suggest do 25mm/30mm or you will eventually regret it. I can post some pics once I get a camera.
Old Dec 17, 2008 | 01:52 AM
spinviper's Avatar
spinviper
Show me the picture of 25 Front and 30 rear please. I might change my mind.
And what brand u guys recommend ?
Old Dec 17, 2008 | 02:00 AM
gregtotheb's Avatar
gregtotheb
^project kics or ichiba v2.
Old Dec 17, 2008 | 05:46 AM
z-u-later's Avatar
z-u-later
H&R & Ichiba sells the 25mm spacers. Project Kics is the only one that sells the 30mm spacers for our Z (but they are hard to get). It took me over a month to find the hubcentric rings for the 30mm spacers.
If you wait another week, I will be selling my setup. I'm mounting aftermarket rims with wider tires so I can no longer use my spacers. I've got the H&R 25mm hubcentric spacers & Project Kics 30mm spacers (with hubcentric rings). Both have built-in bolts and easy to install.
Old Dec 17, 2008 | 03:24 PM
stunter4hire's Avatar
stunter4hire
will the 25mm front and 30mm rear fit a 03 touring with 06 touring wheels?
Old Dec 17, 2008 | 03:44 PM
ohSIXz's Avatar
ohSIXz
30/30!!!! and that 30 in the rear still wont make it totally flush, but itll get close. the 30 on the front is almost perfect.
Old Dec 17, 2008 | 05:56 PM
Ilike350Z's Avatar
Ilike350Z
heres mine H&R 25mm F,R
Old Dec 17, 2008 | 08:16 PM
z-u-later's Avatar
z-u-later
Yes, it'll be perfectly flush.
Old Dec 30, 2008 | 07:20 PM
spinviper's Avatar
spinviper
Well it true , Project Kics 30 mm is very hard to find.
By the way I see one in e-bay.
http://cgi.ebay.com/ebaymotors/_Car-...3A1|240%3A1318
Is this the one ?
What is that mean by Spacer M12x1.25 5x114.3 30mm ?
Old Dec 30, 2008 | 07:23 PM
SS728's Avatar
SS728
25mm would give it a nice stance.
30mm for more flushness in rear.
Old Dec 30, 2008 | 08:15 PM
z-u-later's Avatar
z-u-later
Yeah, that's it but I would contact one of the forum vendors here if I were you. I think CZP carries the Project Kics spacers. You will also need to order the 30mm hub rings, which is about $30 more.
