Photoshop help needed please....
Old Dec 29, 2008 | 02:21 PM
Stogge's Avatar
Stogge
Default Photoshop help needed please....
So, I was hoping that someone would be kind enough to help me visualize what the following wheel/car combination will look like in 19"... Any help on this would be much appreciated! Also the wheels are 19x9 +26 & 19x10 +26, are these sizes good for a 350?
Old Dec 29, 2008 | 04:24 PM
mariar508's Avatar
mariar508
a drop and some spacers should suffice
Old Dec 29, 2008 | 04:38 PM
Stogge's Avatar
Stogge
C'MON Guys! I'm Drinkin' and just dropped some money! Help Pleaze!
Stogge's Avatar
Stogge
Why Spacers? Help a Nood Plz....
Old Dec 29, 2008 | 04:44 PM
fairladyinit's Avatar
fairladyinit
Just go to your local wal-mart and grab a pack of white t's, some spongebob boxers and levis jeans and you wont be nood
Old Dec 29, 2008 | 04:46 PM
Stogge's Avatar
Stogge
Old Dec 29, 2008 | 05:06 PM
sry110's Avatar
sry110
IMO those wheels will look good. I like that gray color against the solar orange.
To give you an idea of the fitment, here is a picture of my car with my previous set of wheels which were 19x9 +25 front and 19x10 +25 rear, with Toyo T1R 245/35/19 front and 275/35/19 rear. The wheels you are looking at with +26 offset will be 1 mm more sunken in than mine were. The spacer comment mariar508 made was because you could push these wheels out even farther (with spacers) before hitting the fender lip. Just estimating, I would say a 5mm spacer would get you out to the edge before you would have to roll your fenders.
Old Dec 29, 2008 | 05:09 PM
Stogge's Avatar
Stogge
Hey, thanks for the great info and the Pic! 1mm shouldn't make that big of a difference and I think yours look PERFECT! Also, is your car lowered? If so, how much, and what parts did you use (springs, camber arms, etc...)?
Once again, thanks for the helpful info!
Old Dec 29, 2008 | 06:42 PM
SS728's Avatar
SS728
This setup would look awesome!
Gave you a drop as well,
Old Dec 29, 2008 | 06:49 PM
Stogge's Avatar
Stogge
Dayyyyyum!! That is the Hot ****!!! Thanks for the help bud!!
Old Dec 29, 2008 | 07:35 PM
sry110's Avatar
sry110
No problem, glad to help. Lowered on Hotchkis springs (lowered about .75" rear, 0.5" front I think), stock shocks, no camber correction so it's a little more negative than stock. As far as the spacing, you can see that the rears could be pushed out a bit more before the tires rub, but it depends on where your camber is set too.
sherm
Apr 11, 2020 05:21 PM
