Any pros or cons on having bigger wheels in rear than front?
Old Dec 30, 2008 | 01:06 PM
martini3p's Avatar
martini3p
Default Any pros or cons on having bigger wheels in rear than front?
For example 18" in front and 19" in rear?
Thanks
Old Dec 30, 2008 | 01:36 PM
terrasmak's Avatar
Pro= Same size sidewall front and rear
Looks great
Con= Looks bad to some, tires will be more expensive ,
Old Dec 30, 2008 | 01:47 PM
Its just insane!
Old Dec 30, 2008 | 01:49 PM
Nexx's Avatar
Nexx
Originally Posted by davidv
Its just insane!
+1
Beyond comprehension.
Old Dec 30, 2008 | 02:51 PM
paposalsa's Avatar
paposalsa
Some Corvettes and other RWD cars are like that. Nothing wrong if the tire ratio is kept for the front and rear.
Old Dec 30, 2008 | 03:07 PM
Spike100's Avatar
Spike100
You present a very good question. I think that 18” front-wheels with 19” back-wheels is a nice setup.
Pros:
  • You have about the same sidewall height front and rear with this mixed-wheel-size setup. It looks good and provides a more comfortable ride than you get with all 19” wheels.
  • Some drivers swear you get better handling when the sidewall height is nearly identical front-to-rear. I have no idea if that is true, but it does makes sense when you consider that the higher the tire’s sidewall, the more flex you will have during hard- cornering.
  • Tires on 18” wheels have a higher sidewall and often provide a more comfortable (softer) ride than 19” wheels.
  • Curb-rash happens more frequently on front wheels, so the higher your tire’s sidewall the more likely you avoid damaging your expensive wheels.
  • Generally (but not always since it varies by brand) tires for 18” wheels cost less than those for 19” wheels, so you might save some $$ buying the front tires for a shorter wheel.
  • 18” wheels cost less than 19” wheels, so that might save some $$. But, this advantage could be negated by the deals you get when buying four wheels in a “set,” all the same size.
Cons:
  • You might pay more for a mixed set of 18” and 19” wheels. But then again, maybe you could buy this setup for less. It all depends upon how hard you shop.
  • If you decide to sell your wheels, you may find fewer buyers willing to go with a mixed 18”/19” setup. That means you might get less $$ for your wheels.
There are probably other points I’ve missed.
--Spike
Old Dec 30, 2008 | 06:54 PM
sry110's Avatar
sry110
It's not crazy at all. I believe the OEM 2006+ RAYS wheels were 18" front and 19" rear. If it was unheard-of, I doubt Nissan would have done that.
Old Dec 30, 2008 | 08:41 PM
Triple8Sol's Avatar
Triple8Sol
As long as you choose tires sizes that keep you in spec, you'll be fine.
Old Dec 31, 2008 | 01:23 PM
ChinaClipper's Avatar
ChinaClipper
18F and 19R is what I am running!
Attached Thumbnails Any pros or cons on having bigger wheels in rear than front?-rideztimez2008-321a.jpg
Old Dec 31, 2008 | 03:44 PM
trodis's Avatar
trodis
Its known as a "staggered setup". Try searching on it on google.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
