Offset question (yes I searched)
If my research is correct, 9.5 inch wheels with +35mm offset will not fit on the front of my Z without spacers. (rub the inside)
I also read that a 9.5 inch wheel with (less) than a +22 offset might rub the fender. (rub outside)
Am I correct in assuming that the 9.5 inch SSR Comp-H wheels that come with a +35mm offset can "thread the needle" by simply installing a 10mm spacer? (9.5 inch, +25mm) Again, this is only a question regarding front fitment.
***Update!***
9.5" wheel with +35mm offset and 275/40 17 tire = RUB! (On the inside, not the fender side)
I could turn the wheel with my hands, but I could also hear it rubbing and, when I took the wheel off, I could also see the black mark it left just from turning it by hand a little.
Oh well. I guess I am going spacer shopping...
***Update!***
It looks like I have just a little over a half inch gap (inside) with my 8.5 +31mm. I thought it would be real close if I just bolt it (9.5 +35mm) on.
Are you sure?
If it clears when parked, should it also clear under hard cornering?
Are you sure?
you can run a 9.5" wheel with a +5 offset up front dropped 1.5" with 1.6 degrees camber and not even be close to rubbing with a 255 tire. prolly run a 275mm tire no problem as well.
To OP: Do not mean to hijack your thread.
***Update!***
I just bought the identical set of SSR wheels I have on my Z now (from another Z owner), in hopes of replacing my 8.5 inch fronts with the 9.5 inch rears from the set I just bought. (SSR Comp-H wheels, if anyone wants to know.)
I am thinking 10mm. I will track the car with these spacers, so they need to be a good, solid fit. Any suggestions?
