06 rays oem wheels
Old Jan 17, 2009 | 04:57 PM
nick123's Avatar
nick123
Default 06 rays oem wheels
I just purchased the oem rays wheels fromt eh 2006 z. I currently have 240 40 18 upfront and 265 35 19 in the rear.
whats the biggest spacer i can use.
would 20mm front and 25 mm rear be too aggressive
Old Jan 17, 2009 | 06:20 PM
StoneZtech's Avatar
StoneZtech
I would run 15 all the way around..
You don't want to look RRICE!!
Old Jan 17, 2009 | 07:02 PM
Toby-22's Avatar
Toby-22
^ +1, they're not as tucked in as other stock 350z wheels. Also i would change the tires out back to 285/35/19 for a more aggressive look.
Old Jan 17, 2009 | 07:23 PM
nick123's Avatar
nick123
but then i would have an issue with the vdc.
nick123's Avatar
nick123
so 15 mm all around should be fine....Do ii need longer studs
Old Jan 17, 2009 | 07:37 PM
Toby-22's Avatar
Toby-22
Thats why you'll change the front tires as well to go with the rear You wont have any VDC issues
Old Jan 17, 2009 | 07:38 PM
Toby-22's Avatar
Toby-22
U can get 15mm spacers with built in studs
Old Jan 17, 2009 | 08:28 PM
nick123's Avatar
nick123
i have a set of 10 mm spacers layin around...do you think thats suffecient..
Old Jan 17, 2009 | 09:14 PM
Toby-22's Avatar
Toby-22
^ u had those laying around and didn't even bother fitting them??? Yes they are suffecient. Also go with wider tires like i said. THey will look so much better, especially from the rear
Old Jan 17, 2009 | 09:56 PM
dhays's Avatar
dhays
How big would the fronts need to be, 255/40/18?
Old Jan 18, 2009 | 09:20 AM
nick123's Avatar
nick123
Alrighty...that would mean i need to buy new tires all around...UGGGG
Old Jan 18, 2009 | 09:26 AM
Toby-22's Avatar
Toby-22
I would do 265/35/18 up front and 285/30/19 for the rear. Thats from comparing with stock setup, im not sure what the wheel specs are for the GT rims. I know the rear is 19x10, not sure with the front.
Old Jan 18, 2009 | 09:30 AM
cdoxp800's Avatar
cdoxp800
OEM 06 GT wheel Specs
Front 18 x 9, 245/40-18
Rear 19 x 10, 265/35-19
I am running a 275/30-19 on the rear on mine.
Wheel / Tire Size Comparer
http://www.wheelsmaster.com/rt_specs.jsp
Old Jan 18, 2009 | 10:14 AM
Adrenaline Rush's Avatar
Adrenaline Rush
What do typical 15mm spacers with studs weigh?
Old Jan 19, 2009 | 06:31 AM
nick123's Avatar
nick123
can i keep the 245 40 18 front and do a 285 30 19 rear without it driving funny and any vdc issues
Old Jan 19, 2009 | 09:46 AM
Papa bear says too aggressive.
Momma bears says too wimpy.
Baby bear says just right.
Old Jan 19, 2009 | 09:53 AM
The tires look the same height to me.
Old Jan 19, 2009 | 12:37 PM
nick123's Avatar
nick123
so thats a yes...I can do 345 40 18 front and 285 30 19 rear...Would it drive funny or lo9look funny...Somone tell me as im buying them today
Old Jan 19, 2009 | 12:44 PM
kham25's Avatar
kham25
Dude do 255/40/18 and 285/35/19 Thats what im running at it looks great
Old Jan 20, 2009 | 11:35 PM
dhays's Avatar
dhays
Pictures?
Obadabot
Jun 18, 2023 11:31 PM
