245/35/19 change to 255 or 265
Old Feb 26, 2009 | 11:20 AM
350Z_NOW's Avatar
350Z_NOW
Default 245/35/19 front change to 255 or 265 0r 275
I'm going to change my front tires from 245/35/19 to 255 or 265 or 275. Which width would you recommend?
Old Feb 26, 2009 | 11:25 AM
terrasmak's Avatar
depends on rim width and offset
Old Feb 26, 2009 | 11:29 AM
Done Deal DR's Avatar
Done Deal DR
Absolutely impossible to say without the specs of the wheel.
Old Feb 26, 2009 | 11:31 AM
350Z_NOW's Avatar
350Z_NOW
OK my front wheel specs: Work Meister S1 3p 19x9.5 +19 with 5.5mm spacer makes it +13.5, H&R sports springs 1.3 drop.
The reason why I want to change it is because 245 is a little stretched for me, when I view the tire from the front of the car, you can't see itjust the lip of the rim. I want it flush to the fender... looks more beefed up and clean...
sample pics
driver side
<a href="http://s16.photobucket.com/albums/b41/DINOL/?action=view&current=DSC_0477.jpg" target="_blank"><img src="http://i16.photobucket.com/albums/b41/DINOL/DSC_0477.jpg" border="0" alt="Photobucket"></a>
passenger side
<a href="http://s16.photobucket.com/albums/b41/DINOL/?action=view&current=DSC_0479.jpg" target="_blank"><img src="http://i16.photobucket.com/albums/b41/DINOL/DSC_0479.jpg" border="0" alt="Photobucket"></a>
Old Feb 26, 2009 | 11:35 AM
terrasmak's Avatar
Go 255 then , or remove your spacer and do the 265
Old Feb 26, 2009 | 11:38 AM
350Z_NOW's Avatar
350Z_NOW
How will a wider tire handle as for the front? this car is daily driven.... sometimes track/autocross. I'm shooting towards 255 or 265 I don't think I want to run 275 front...
Old Feb 26, 2009 | 11:43 AM
Done Deal DR
The closer you get to a square setup the less understeer (in theory, on an otherwise factory suspension setup) you will have. The front will also feel a little heavier.
I agree with Terrasmak's suggestion. Also realize if you don't go with the same brand tire that some brands will dramatically differ in actual width and sidewall shape that could make it rub severely.
I'm assuming you have rolled fenders, also expect to rub under full compression turns and dips.
Old Feb 26, 2009 | 11:48 AM
Done Deal DR
Also, I doubt even without the spacer you would be able to run a 275 with that offset, way too aggressive of an offset to even consider a 275, so good call on that one. Even a 255 with the spacer will be pushing it if you're a normal guy (AKA not a stretched tire/aggressive offset guy that apparently doesn't mind rubbing every 2 seconds).
Old Feb 26, 2009 | 12:05 PM
350Z_NOW's Avatar
350Z_NOW
I'll probably stick with 255 ... with spacers, thanks guys
Old Feb 26, 2009 | 12:11 PM
Done Deal DR
Good call, it should be a perfect fit depending on tire choice. You always have the option of removing the spacer as well if you run into problems (which I doubt you will given your pics and specs), no biggie. Enjoy.
Old Feb 26, 2009 | 01:34 PM
350Z_NOW's Avatar
350Z_NOW
Thanks for helping!
Old Feb 26, 2009 | 01:52 PM
Done Deal DR
Be sure to post pics after the tire swap! I'm looking to go with a 255 for my front (20x9.5) as well, but I've still got a ton of tire to burn!
Old Feb 26, 2009 | 09:18 PM
350Z_NOW's Avatar
350Z_NOW
sure i will... i need to sell my 245's
Old Feb 26, 2009 | 09:27 PM
zSupreme7's Avatar
zSupreme7
You want either 255/35 or 265/30. Either one will be good.
Old Feb 26, 2009 | 10:17 PM
350Z_NOW's Avatar
350Z_NOW
255/35....more meat
Old Feb 27, 2009 | 10:17 AM
scotts300's Avatar
scotts300
Important question - what is your rear tire size? If it's 275, I'd probably go with the 265/30 or 265/35. Your rear tires look stretched, too, so I'm guessing 275 on a 10.5" wheel. Change that one, too (IMO).
Old Feb 27, 2009 | 11:22 AM
350Z_NOW's Avatar
350Z_NOW
my rear is 19x11.5 with 285/30, I was thinking to change it with 295/30
Old Feb 27, 2009 | 01:04 PM
scotts300's Avatar
scotts300
Wow, an 11.5? That should have a 305, minimum. . . I'd probably go 265/30 or 275/30 front with 305/30 rear. What is the offset on that 11.5?
Old Feb 27, 2009 | 10:52 PM
350Z_NOW's Avatar
350Z_NOW
i'm thinking of putting 295/305 but 305 will have rubbing issues. the offset is +11.5 because i'm running 5.5mm spacers, originally its +17.
Old Feb 28, 2009 | 11:10 AM
350Z_NOW's Avatar
350Z_NOW
yeah im getting 255/35
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
