Same Tire Size All Four Corners
Old Mar 2, 2009 | 11:28 AM
flyzmd80's Avatar
flyzmd80
Default Same Tire Size All Four Corners
Just looking for advice and discussion on this subject. Any thoughts...pro or con?
Old Mar 2, 2009 | 11:29 AM
Motormouth's Avatar
Motormouth
never been done before... blaze the trail.
Old Mar 2, 2009 | 11:40 AM
z-u-later's Avatar
z-u-later
Yep, no other 350Z drivers have ever thought of this before.
Old Mar 2, 2009 | 11:42 AM
Motormouth's Avatar
Motormouth
I wonder if you do a search, maybe someone else might have at least asked about it in the past 6 years.
Old Mar 2, 2009 | 11:51 AM
flyzmd80's Avatar
flyzmd80
Ya got me crying UNCLE !!!!!!
Off to search I go!!!!!!!!!!!!!!
Old Mar 2, 2009 | 12:04 PM
Motormouth's Avatar
Motormouth
but yeah, not too uncommon of a set up.
Old Mar 2, 2009 | 12:10 PM
Entaille's Avatar
Entaille
pros: you can rotate your tires and save money
cons: you miss out on a lot of handling characteristics that make the Z moar fun to drive
Old Mar 2, 2009 | 12:15 PM
kyx4n's Avatar
kyx4n
also if you have TCS, they will b*tch at you
Old Mar 2, 2009 | 12:53 PM
350z-Jim's Avatar
350z-Jim
My car had 255 all around and I have VDC and it wasn't a problem. I know that you should have a staggered setup and some guys say the TCS goes all bananas on you if it's not staggered properly but my car was non-staggered for a long time and it's fine.
Guess it depends on the car for whatever reason.
Old Mar 2, 2009 | 01:02 PM
Entaille's Avatar
Entaille
hmm I think it was VDC that had iccues with it, not TCS?
Old Mar 2, 2009 | 01:52 PM
Thanks for asking but the subject is 5 years old.
Old Mar 2, 2009 | 02:56 PM
Ericshere03's Avatar
Ericshere03
Originally Posted by 350z-Jim
My car had 255 all around and I have TCS and it wasn't a problem. I know that you should have a staggered setup and some guys say the TCS goes all bananas on you if it's not staggered properly but my car was non-staggered for a long time and it's fine.
I Second that, i am running 245/45/18 all around on 4 rear track wheels, TCS does just fine, and I get less understeer...
Old Mar 2, 2009 | 07:00 PM
z-u-later's Avatar
z-u-later
If you've done some research, you would have known this is not true.
Old Mar 2, 2009 | 07:30 PM
Spike100's Avatar
Spike100
Wow! …Tough crowd on this one.
I think you ask a good question, and your search will provide a variety of opinions with, unfortunately, a lot of arguments with misinformation and bad advice.
You didn’t mention your wheel sizes or your car’s equipment (if you have TCS or VDC). So… answering your question requires some assumptions. I’m assuming you have the same size wheels front and rear (a legitimate assumption considering a question that is asks about an “all-square” tire setup). I’m also going to assume this wheel size is 18x8”.
If my assumptions are correct…
  • The best sizes for an all-square vertical/staggered setup on 18x8” wheels (This setup works perfectly with TCS and VDC.): 245/40-18” front with 245/45-18” rear.
  • The best sizes for an all-square (ignoring vertical stagger) setup on 18x8” wheels: 245/45-18” front and rear. This size will be OK with a car equipped with VDC.
  • If your car is equipped with VDC, the all-square size you do not want is 245/40-18” all around. This size will result in unwanted VDC activation.
An “All-Square” setup’s advantage is the ability to rotate your expensive tires. Some drivers also prefer its more neutral handling (something I also notice). If you do install an all-square setup, you should realize that your car will drive differently because it has less under steer. That isn’t a problem for an experienced driver, but an operator accustomed to more safety from a staggered setup could be in trouble quickly with a neutral setup. Keep that in mind if you decide installing the same width tires front and rear.
--Spike
Old Mar 2, 2009 | 08:17 PM
scotts300's Avatar
scotts300
Well taken.
Old Mar 2, 2009 | 10:09 PM
Shift__Z's Avatar
Shift__Z
just got my RE01Rs from tirerack 590 shipped 245/45/18 all fours . From what I hear a lot of people who track their cars found this setup ideal.
Old Mar 2, 2009 | 10:34 PM
terrasmak's Avatar
Please someone clue me in on this one!!!! Usually a square setup makes it more fun to drive
Old Mar 2, 2009 | 10:58 PM
hotfiyah's Avatar
hotfiyah
Unfortunately, i have a 245/45/18 set up with 18-8.5 i believe.
it was set up like this when i got the car.
my dream is 245/45/18 up front
and 275/?/19 in the back
8.5 up front
9.5 in the back
we'll see what happens though...
it's fine, but there is a bit of sliding...
with a staggered set up, i assume you'd have a bunch more fun.
but rotation would be a bit worse....
iuno. just sayin'
Old Mar 3, 2009 | 11:38 AM
Faboo's Avatar
Faboo
the people on this site care mostly about straight line speed and looks.....
big rear tires help accel. and let u put big nice wheels....
so u'll hear alot of flak
look at the racing section and ask people that actually care about real handling
Old Mar 3, 2009 | 05:48 PM
Shift__Z's Avatar
Shift__Z
exactly
