Best Tire Pressure?
Old Mar 3, 2009 | 06:27 AM
Lento's Avatar
Lento
Default Best Tire Pressure?
Does anyone run their tires lower than 35psi to get better performance?
I know the manual states 35 psi, but I figure if you drive the car hard that probably gets up to about 37-38 psi and that seems a bit high.
Does anyone run lower than 35psi on a regular basis. I know it depends on weather as well, but assume the weather is like 60-80 degrees, with stock Bridgestone RE 050A's
Old Mar 3, 2009 | 06:37 AM
Motormouth's Avatar
Motormouth
I roll wit 40psi on da highwadizzles. but fo performanc type jeezy, I go all BOUT dat 33-35psi jon. drag fizzling? yo dawg you needs ta get down in tha like, 25psi range herd? dat is whur da gripple be at.
I dun really be understanding what all you be needin ta do wit it. feel me son?
holla back naw
Old Mar 3, 2009 | 06:44 AM
Lento's Avatar
Lento
holla back naw
Of course I feel you. I'm a graduate of Ebonics Language Lessons!
http://www.youtube.com/watch?v=EndozxolXKE
Old Mar 3, 2009 | 07:18 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Mar 3, 2009 | 07:58 AM
Z04's Avatar
Z04
Originally Posted by vo7848
Moved...
should have closed it instead it jsut encourages him to create more worthless threads like this one
Old Mar 3, 2009 | 09:25 AM
terrasmak's Avatar
optiminal performance varies from tire to tire, but i do know that optimal pressure when hot is around 38 on the front and a psi or two lower in the rear. The only time i would suggest running lower pressure(cold tires) is when its being driving to the point the tires are getting over 40 PSI hot (track)
Old Mar 3, 2009 | 09:35 AM
Lento's Avatar
Lento
^thanks
Old Mar 3, 2009 | 09:41 AM
j.arnaldo's Avatar
j.arnaldo
30 psi, due to the harsh ride (i.e. to reduce the jarring effect caused by Puertorrican roads/politicians!) I've been doing it for over a year and, so far, no problemo.
____________________________________________________________ _________________________________________________________
'O4 Touring Coupe: NO feathering, NO oil-consumption issue, FLAWLESS AT!!!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
