FAQ: Official wheel "SPACER" thread!
Old May 3, 2009 | 10:31 PM
  #61
Darkness75's Avatar
Darkness75
any one ,,,going to place my order .
pics or link to pics would be great
thanks
Old May 4, 2009 | 03:48 AM
  #62
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by Darkness75
^^ +1
i will order my lowering springs and camber front n rear and spacer 2gether so i can`t do the measuring step, my plan is to go 20mm F & 25mm R and GF210 Springs.
my Q is : with lowering the Z i must got less mm spacer to get flush look ??
as if i get 15mm F 20mm R with lowering i get the look of 20mm&25mm ??
or not
thank you
yes, you are right, it will require less as the drop alters camber, but still, best thing to do, is INSTALL your springs, install your camber kit then measure - reason being is wheel flushness is a subjective issue and you have to decide how flush you want it......to some, a 5mm difference in spacer is the difference between being happy or not........so i still suggest you measure and decide...........i know this because im currently wanting 15mm spacers, because with the after market wheels im running, im thinking 15mm would be better than the 20mm i currently have installed........."to each their own"
-J
Old May 12, 2009 | 10:17 PM
  #63
Darkness75's Avatar
Darkness75
let me ask about it in another way :
is better to go with spacer out of the fenders and get a negative camber to fix it to flush Or from inside fenders and positive to reach flush ?
( one more time : get 25mm or 30mm and bring it in with negative camber or 20mm/15mm and pull it out with positive camber)
when i say better i mean better in handling, looks, safer for tires and its mechanical part of the tires.
thank you
Anan
Old May 14, 2009 | 07:23 PM
  #64
350Speed's Avatar
350Speed
Hi,
I went through the thread, but didn't see anybody has the same setup as I do. Therefore, I decided to ask and hopefully someone will chime in. I'm thinking to get wider tires such as 245/40/18F, 275/40/18R or something similar without rubbing. Here is my current setup.
Wheels: OEM Rays Track
Spacers: H&R 25mm (F & R)
Springs: Tein S-Tech
Thanks for your help.
Old May 15, 2009 | 03:23 AM
  #65
07rdsterGT's Avatar
07rdsterGT
Originally Posted by Staisman
I have OEM 18" wheels and I want to put spacers without any cut/sand/seal my rear fenders (oem suspension). So as I understood I need 20 and 25 mm spacers with hub centric rings? Which spacers can u recommend for easy installation? And do I need replace wheel studs?
There is some example as I want with rims that I have:
That's my car when I still had my stockies. I had 30mm rear and 25mm front.
KICS with Hubcentric rings is what is on the car and also is one of the easiest to install because the studs are already set in the spacers.
Just torque to 85lB's like your wheels and thats it.
Old May 15, 2009 | 08:59 AM
  #66
JasonZ-YA's Avatar
JasonZ-YA
^ good addition...
thanks...
-J
Old May 17, 2009 | 09:17 PM
  #67
o2sys's Avatar
o2sys
My wheel setup: G35 19" Forged wheels 19x8 Front 245/40/19 & 19x8.5 Rear 255/40/19.
Spacers: 20mm Front & 25mm Rear
The fronts are nice and flush, the rears are sticking out and rubbing like a crazy! Should i get 20mm for the rears or fender roll?
Old May 18, 2009 | 04:42 AM
  #68
JasonZ-YA's Avatar
JasonZ-YA
^ there is no point in decreasing your spacers if you havent rolled your fenders.......so fender roll first and then go from there...
-J
Old May 18, 2009 | 05:04 AM
  #69
07rdsterGT's Avatar
07rdsterGT
Originally Posted by JasonZ-YA
^ good addition...
thanks...
-J
The torque spec was one of the only things I was able to read on the paper that came with my KICS (it was all in Japanese).
Old May 18, 2009 | 05:22 AM
  #70
JasonZ-YA's Avatar
JasonZ-YA
lol.. ya...i forgot about that....i took one look at the instructions and was like......ummmm okay..
-J
Old May 18, 2009 | 10:15 AM
  #71
o2sys's Avatar
o2sys
would putting the 20mm on the rear and the front 25mm solve my problem? (i cant get my fenders rolled any time soon)
Old May 18, 2009 | 10:29 AM
  #72
cheshirecat79's Avatar
cheshirecat79
I was about to suggest this.
Defnitey try it out- it may fix the issue.
Old May 18, 2009 | 10:36 AM
  #73
o2sys's Avatar
o2sys
the front offsets are 30mm 19x8 w/ 25mm it will make it 5mm
the rear offsets are 33mm 19x8.5 w/ 20mm it will make it 13mm
is this kinda of weird?
Old May 19, 2009 | 08:34 AM
  #74
cheshirecat79
You'll be able to tell how weird it is when you swap them.
Old May 21, 2009 | 06:01 AM
  #75
350Speed's Avatar
350Speed
Originally Posted by 350Speed
Hi,
I went through the thread, but didn't see anybody has the same setup as I do. Therefore, I decided to ask and hopefully someone will chime in. I'm thinking to get wider tires such as 245/40/18F, 275/40/18R without rubbing. Here is my current setup.
Nobody has the same setup as I do.
Old May 21, 2009 | 09:05 AM
  #76
o2sys's Avatar
o2sys
somehow the rubbing has stopped to a certain point. At first it would just constantly rub. After three days unless its a serious bump or waviness on the road will not rub.
Going to lower the car soon so getting the fenders rolled anyways over the weekend.
Old May 23, 2009 | 09:42 AM
  #77
Miketsi's Avatar
Miketsi
Originally Posted by kamikaZ
I know a lot of people run spacers on the stock setups..
Can anyone recommend their preferred / "tried and true" spacer setups for the OEM track wheels ('03)? I'm about to take the Volks off and I'm not looking forward to the narrow wheels.
What a great question.
I want to know the best spacers + studs for 06 base wheels, to give the most flush with the fender look?
Old May 23, 2009 | 04:36 PM
  #78
chrisjersey06's Avatar
chrisjersey06
Hey guys, I am looking to order some spacers this week, so I had a question about the hubcentric rings (before I saw this thread) so I gave CZP a call. They said that although the Project Kics rings will fit on the CZP spacers, that with stock wheels, I do not need the rings. Then I came on here and did a search, found this thread, and see that people in here are running the hub-centric rings with their stock wheels.
I don't know why CZP would tell me that you don't need them because I'm ordering from them anyway (had many good experiences with CZP parts in the past), and would have also ordered the rings from them if they told me I needed them. Which is it??
Any downside to running them without rings? Does anybody on here have spacers without them, any bad experiences? I'm confused now because I know CZP knows their stuff..
Old May 25, 2009 | 06:24 AM
  #79
stinky350z's Avatar
stinky350z
hi guys , i have a question so if i have aftermarket wheels i dont need to run hubcentric rings, i have ssr sp1 19x10.5 offset 24 , 88mm , thank u so much
Old May 30, 2009 | 11:37 PM
  #80
krypto's Avatar
krypto
i have the 5-spoke anniversary stock rims and im running 235's in the front and 255's in the rear....which spacers should i get to push the tires out to the max without rubbing issues? not lowered, everything is stock. thanks
