FAQ: Official wheel "SPACER" thread!
Old Sep 20, 2017 | 01:53 PM
  #1361
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by the rook
Attachment 452918
Attachment 1
Attachment 452916
Ordered H&R 15mm bolt on spacers all the way around.
19/9 et25. 245/35
19/10.5 et20 265/35
Lowered almost 2 inches now.
Shooting for a half inch lower all around.
Setting camber at -2.2 front -2.5 rear.
Fenders are rolled but not pulled or flat rolled.
Thought??? Yes, No?
Pics of similar???
Just in for some feedback and similar setups.
Thanks.
I'm confused..... well, more than normal.
Your quoted specs (and pics?) are before or after spacers?
Old Sep 20, 2017 | 03:16 PM
  #1362
the rook's Avatar
the rook
Oops. Sorry. Should be clarified.
The pictures I took are of my wheel set up without spacers. I just ordered them from concept Z today.
The wheel and tire specs however are my current set up.
Old Sep 20, 2017 | 07:46 PM
  #1363
djnekkon's Avatar
djnekkon
I realize now that after I slipped on the spacers, the wheel hub rings (and now likely the wheels themselves) weren't fully flush with the hub face due to the spacers taking up 5mm of the hub ridge that the rings slide over and therefore not allowing the wheels to flush up and giving me a false torque reading.
no damage to the wheel itself?
Old Sep 20, 2017 | 09:44 PM
  #1364
MicVelo's Avatar
Attachment 452918
Attachment 1
Attachment 452916
19/9 et25. 245/35
19/10.5 et20 265/35
Thought??? Yes, No?
Pics of similar???
Thanks.
So, you're going with 9" front at +10 and rears at 10.5 +5 and you're dropping it another 0.5"? Well, I have no say in this other than "If it fits and you're happy with it...."
Personally think it looks fine but your choice.
Old Sep 20, 2017 | 09:46 PM
  #1365
MicVelo's Avatar
No, never damaged a wheel due to improper mounting.
Now if someone could do something about those mobile curbs that jump out to hit cars' wheels....
Old Sep 21, 2017 | 08:25 AM
  #1366
the rook's Avatar
the rook
No garuntees I'm going lower. Hoping to see some similar setups. May need to roll fenders a little more. My next set of wheels and tires will be less function and more fashion. Lol. These are my track wheels/tires.
Old Jan 26, 2019 | 04:02 AM
  #1367
MicVelo's Avatar
Originally Posted by Jamie Smith
Hello everyone, recently I wanted to put the spacers on my Nissan. A lot of sites looked. Could not find anything. Then came across this site _____________________ Can someone help?))
Wow, someone went to a lot of trouble to look stupid.
EDIT: Site has been condemned by MacAfee. User banned.
Old May 11, 2026 | 06:57 PM
  #1368
jarguess's Avatar
jarguess
5 Year Member
Question z1 motorsports spacer wheel studs
Sorry if this has been answered before, but I search the thread for z1 and didn't find anything.
I have a set of z1 motorsport 20mm bolt on spacers. One of the studs in the spacer is broken. These studs have a knurl diameter of over 22mm and I cant find a replacement. Can any body provide a part number for a replacement stud?
Old May 12, 2026 | 05:28 AM
  #1369
Heel Til I Die's Avatar
Heel Til I Die
Have you tried contacting Z1?
Not sure I would want to mess with a replacement stud. I would just get a new set of spacers.
Old May 12, 2026 | 07:50 AM
  #1370
jarguess's Avatar
jarguess
5 Year Member
I've reached out to z1 but they have not responded. I also reached out to dorman with all the measurements and they can't help either.
Seems ridiculous to me to spend another $100 on a set of spacers for a $3 wheel stud.
Old May 12, 2026 | 07:54 AM
  #1371
Lucky736's Avatar
Lucky736
Are there any markings on the head of the stud? Have you removed it yet, you may have to in order to find them.
As far as a new pair from Z1, that's way overkill. Not for Z1's pocket, but I am sure even they would say just replace the stud before buying another pair of spacers.
Old May 12, 2026 | 09:53 AM
  #1372
jarguess's Avatar
jarguess
5 Year Member
There are no markings on the stud. I've removed the stud and taken all the necessary measurements with a pair of digital calipers that give measurements in both inches and millimeters. I gave that information to the sales department at dorman and they said they don't sell a matching stud.
Old May 13, 2026 | 09:57 AM
  #1373
jarguess's Avatar
jarguess
5 Year Member
Finally heard back from z1. They don't sell the studs and can't provide a part number. Then told me I need to buy another set of spacers.
I know there are brands that have studs that can be replaced but they cost double what the z1 spacers cost.
I bought the car with the spacers and the broken stud. I didn't break it. I always start my lugs by hand. I might use a torque wrench to zip them down but not tighten them. I use a torque wrench. I've worked in a couple shops and slamming things together with a torque wrench is actually a pet peeve. My point is I'm not to worried about breaking another stud so I'm just going to buy another set of the cheaper z1 spacers.
Old May 14, 2026 | 07:55 AM
  #1374
terrasmak's Avatar
cheap micrometer and a search in the Dorman catalog will work. I had to do that for my trailer
Old May 14, 2026 | 08:14 AM
  #1375
jarguess's Avatar
jarguess
5 Year Member
The only dorman catalog I could find on their site with measurements was for hd equipment where the smallest stud was m20.
Like I said I measured the stud and sent all the info to dorman and they told me they couldn't match it.
The stud is m12x1.25. total length approx 47mm. The knurl 10mm long with a diameter is 22.3mm. The head is 4mm long with a diameter of 27mm.
Old Jun 20, 2026 | 12:01 AM
  #1376
terrasmak's Avatar
easily found online
Example of the online catalog
Tech Territory
Aug 24, 2023 08:54 AM
o2sys
Nov 19, 2011 11:00 AM
bswanny
Dec 14, 2008 12:56 PM
Dakota_za
Dec 15, 2007 12:19 PM
VIZAGE
Oct 19, 2007 11:07 AM
