can my 06 stock wheels fit 245/45/18(f) 265/45/18?
Old Apr 5, 2009 | 09:31 AM
JunJTan's Avatar
JunJTan
Default can my 06 stock wheels fit 245/45/18(f) 265/45/18?
245/45/18 front, 265/45/18 rear on stock wheels? I did some research on the forum, but. I couldn't find any I information. I appriciate your help.
Old Apr 5, 2009 | 09:33 AM
SuperBlack350z's Avatar
SuperBlack350z
would it fit? yes.
Old Apr 5, 2009 | 09:40 AM
terrasmak's Avatar
on the wheels yes, on the car , maybe.
Old Apr 5, 2009 | 09:50 AM
JunJTan's Avatar
JunJTan
Did you mean the tires size doesn't fit the car or the look?
Old Apr 5, 2009 | 10:39 AM
terrasmak's Avatar
On your car , they are a bit tall for it. 265/40 rear and 245/40 front is actually what you should look at. Better yet, 245/40 front and 245/45 rear
Old Apr 5, 2009 | 12:06 PM
Agree. I think "What size tires fit what size wheels" is a subject that we should address.
Old Apr 5, 2009 | 01:11 PM
JunJTan's Avatar
JunJTan
Sorry I didn't make the title clear to everyone. So 245/40/18 front and 265/40/18 rear is a better size for my car? Thanks for everyone's help.
Old Apr 5, 2009 | 01:43 PM
terrasmak's Avatar
That is correct , but for best handling i would run a wider wheel for those rear tires or drop to a 245/45 rear.
Old Apr 5, 2009 | 01:53 PM
Spike100's Avatar
Spike100
As the members point out here, 245/40-18F and 265/40-18R is the ideal size for overall diameter (but 265 on the rear may not be the right width for your OEM wheels).
However, 245/45-18F and 265/45-18R is off by about 2.5% overall diameter (about the same front and rear), so that will work with your car (even if it’s VDC-equipped). You have a 2.5% speedometer error, which is about 1 mph for every 50 mph on the speedometer, so that’s insignificant.
You mention stock wheels, so I would add this caution: If you have 8” wheels, the 265’s will be bulged (and probably past the tire company’s recommendation which is 9” wheels for 265’s). I think you should be fine here, but keep this in mind. (That’s why terrasmak recommends 245/45-18R.)
--Spike
Old Apr 5, 2009 | 03:01 PM
Its cool. I am conservative and recommend OEM width plus or minus 10 mm. Others may push it a bit farther.
Old Apr 5, 2009 | 03:07 PM
Thumbs up
Speedometer will read 101.27 at 100.0 MPH. The difference is insignificant.
Old Apr 5, 2009 | 03:11 PM
singh's Avatar
singh
_______________
The increased weight of bigger tires will make you slower. And the tire bulge will look retarded. Stick with OEM sizes.
Old Apr 5, 2009 | 04:19 PM
JunJTan's Avatar
JunJTan
Thanks to everyone.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
SharX59
Sep 27, 2015 09:23 AM
