will these fit on my nismo???????????
Old Apr 6, 2009 | 06:00 PM
s2k2nismo's Avatar
s2k2nismo
Default will these fit on my nismo???????????
265/30/19 in front on 9.5 wheel 22 offset
295/30/19 in rear on 10.5 wheel 22 offset
will i have 2 roll the fenders....i want too run -2.5 camber front and rear.
Old Apr 6, 2009 | 06:09 PM
terrasmak's Avatar
yes , but you want a 275/30 front to match your rear tire.
Old Apr 6, 2009 | 06:36 PM
Spike100's Avatar
Spike100
Yes… for sure you must roll your rear fenders.
As terrasmak mentions…
… you need to match your fronts and rears with better “proportions.”
Your stagger-width front-to-rear is excessive and the result is possibly excessive under-steer.
--Spike
Old Apr 6, 2009 | 10:56 PM
2k6-z33's Avatar
2k6-z33
They will fit but you're going to have to roll your fenders so they don't rub.
295 FTW LOL! We still need a exhaust sound clip sir. j/k
Old Apr 7, 2009 | 04:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why do you want to run -2.5 camber front/back? Can't be for handling reasons....just for looks?
as far as the stagger differences, it will work fine, and is within the 3% front/back stagger that is necessary to keep the VDC happy. 275/40 will work as well (about 1.8% stagger front/back) but may look a bit goofy depending on the exact tire. Don't get too hung up on the # printed on the sidewall, spend some time familiarizing yourself with the precise dimensions for the exact tire you are considering. Each tire manufacturer has this info listed on their site. It's all about the contact patch, as determined by the physical dimension, not the # on the sidewall
Old Apr 7, 2009 | 11:02 AM
s2k2nismo's Avatar
s2k2nismo
toyo r888 want even more camber than -2.5, all the guys tracking there cars have even more neg camber....... why wouldnt it handle good???????
Old Apr 7, 2009 | 11:07 AM
Z1 Performance
Former Sponsor
all the track guys with other cars maybe, but you should look at what guys with Z's run
Old Apr 7, 2009 | 11:11 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I could have swore that BJ from 350evo stated that the 350 Grand Am cup cars used to run more negative camber than -2.5 in the rear.
Old Apr 7, 2009 | 12:13 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I know a few "Z" guys running over -3 camber for the track.
Old Apr 7, 2009 | 01:14 PM
Ataru074's Avatar
Ataru074
I'll keep telling you... get a set of 17" or 18" enkei... you'll get back the money of the rims in 2 19" set of R-comp. almost in 1 of 17" (think about 7/800$ for 4 r-comp in 17" 275 all around, one of our sponsors here sells for that amount instead of 1500$)
about the camber for the track... front this car loves it... even with my street kumho xs... -3 is good upfront, the rear you might want to stay around 2.. 2.5 top. the rear gains a lot of camber as the suspension compress, the front way less...
I know toyo says between -2.5 to -5 camber... well.. -2 in the rear works pretty well... and on 19" you don't have so much sidewall flex.
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
