tire help please!!!!!!!
Old Apr 29, 2009 | 01:25 PM
pegleg's Avatar
pegleg
Default tire help please!!!!!!!
I have 225/45/18's in the front and i want to know if i can put on 275/35/18's in the rear without any trouble. i dont have tcs or vdc i just dont want my car to run weird, will this work?
Old Apr 29, 2009 | 01:47 PM
terrasmak's Avatar
Nope, it will understeer badly , will track poorly , will be twitchy at speed. 275/40 would be a better tire. The only prob with that is the car will handle like crap.
Old Apr 29, 2009 | 04:03 PM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
why would the car handle like crap? explain yourself. 245 in the front with 275 in the rear is one of the most common setups.
Old Apr 29, 2009 | 04:20 PM
pegleg's Avatar
pegleg
what about a 255/40 will that work ok with the 225/45 in the front. is it bad to have higher tires in the front than in the rear
Old Apr 29, 2009 | 04:24 PM
pegleg's Avatar
pegleg
or even a 265 40
Old Apr 29, 2009 | 05:27 PM
And why would the car run weird? What is weird?
Old Apr 29, 2009 | 05:40 PM
pegleg's Avatar
pegleg
because the front tires would be taller, a /45 so i dont know if having a shorter tire like /40 will make it run weird.
Old Apr 29, 2009 | 06:51 PM
Spike100's Avatar
Spike100
Say what!?
terrasmak’s response advises against running 225 front with 275 rear (as the OP suggests he wants to do in his original message). Of course that would be an awful setup, and I’m wondering why you need an explanation for why this is bad. You mention 245 front, but the OP says he's using 225 on the front.
Also, terrasmak points out that mounting a shorter tire on the rear than the front is a bad idea (something the OP seems to be planning if you read his first post here). Do you disagree?
--Spike
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
