wheel spacers
Old May 26, 2009 | 11:00 PM
Bumble Z's Avatar
Bumble Z
Default wheel spacers
just purchased some new wheels fno1rc with the rear at 35 mm offset i want to bring it to 20-25mm. my question is will wheel spacers such as eibach pro spacer hurt my performance or in the long run kill my studs or will it ride unnoticed
Old May 26, 2009 | 11:35 PM
Z04's Avatar
Z04
https://my350z.com/forum/wheels-and-...er-thread.html
plus if they did what you are asking there would be a whole bunch of people hurting because a lot are on the wheel spacer band wagon fad.
Old May 27, 2009 | 04:25 AM
Sounds like a great question before buying wheels.
Old May 27, 2009 | 09:04 AM
Bumble Z's Avatar
Bumble Z
originally i wanted a 25mm but they were out of that size so i had to settle for a 35 in the back
Old May 27, 2009 | 02:07 PM
terrasmak's Avatar
just buy quality hubcentric spacers with proper studs and call it good.
Old May 27, 2009 | 02:52 PM
Waiz's Avatar
Waiz
Ib4tl
Old May 28, 2009 | 07:40 AM
scotts300's Avatar
scotts300
What width wheel?
Old May 29, 2009 | 02:16 AM
Bumble Z's Avatar
Bumble Z
Originally Posted by scotts300
What width wheel?
going back down to 17x10 in the rear
Old May 29, 2009 | 06:38 AM
zerafian's Avatar
zerafian
^^you want 25mm spacers hu, thats gonna be a tight fit with them being 10" wide, even with 35mm offset on the rim...whats your camber at? Im gonna guess around -3.
As long as you get an alignment and have camber kit I dont see how it would hurt the car at all.
Old May 29, 2009 | 07:54 AM
scotts300's Avatar
scotts300
The 17x10 +25 FN01R-C fits perfect front and rear.
Old May 29, 2009 | 01:25 PM
Bumble Z's Avatar
Bumble Z
no not 25mm spacer i want to be at 25mm offset with a 10mm spacer on a 10 width they were out of 25mm offset so my fronts are going to be 17x8 25mm and rear at 17x10 35mm offset they are being shipped not mounted yet so im not sure how off it will look or if it would barely be noticable
Old May 29, 2009 | 02:10 PM
scotts300's Avatar
scotts300
Did you consider getting the 17x9 for the front? The 8", although the same as stock, is so bleh since you don't get the contours of the wheel. You'll most likely want a spacer for the front, maybe 10mm or more, and the 10mm for the back as well. GL.
Old May 29, 2009 | 06:16 PM
Bumble Z's Avatar
Bumble Z
yea it comes down again to what 5zigen had in stock i did want the 17x9 for the front but another back order issue and i needed to get these asap just because im traden in my 20's and paying a difference
Obadabot
Jun 18, 2023 11:31 PM
