Official Aggressive Wheels & Fat Tires Thread
Old May 20, 2011 | 09:05 PM
  #2101
2004Black350z's Avatar
2004Black350z
Exhaust Whore
^No
Old May 20, 2011 | 09:24 PM
  #2102
Waiz's Avatar
Waiz
You can't be in both threads
Not even close...
Old May 21, 2011 | 12:01 AM
  #2103
scotts300's Avatar
scotts300
Originally Posted by Max-G
idk if this is fat enough for this thread, but it's fat to me.
18x9.5 -13 235/40
18x10.5 -6 265/35
[/IMG]
No, it's not fat enough. You are at least 20-30mm off, and those offsets are silly.
Old May 21, 2011 | 12:49 AM
  #2104
Max-G's Avatar
Max-G
haha i'm a nowhere man i guess. my car doesn't belong in either thread. or i'm just doing it right with a little bit of each style? rears are actually 275's so it's slightly more fitting :P
the offsets are just as silly as running 295's that never see the track
Old May 21, 2011 | 06:02 AM
  #2105
2004Black350z
Exhaust Whore
go make a slammed silly emo offset thread and be the first
Old May 21, 2011 | 06:39 AM
  #2106
Ak48z's Avatar
Ak48z
Why did you say the rears were 265 first?
Old May 21, 2011 | 09:37 AM
  #2107
ivansz's Avatar
ivansz
19x9.5 +20 front with 245/35, and 19x11 +18 rear with 295/35.
Old May 21, 2011 | 09:50 AM
  #2108
Toby-22's Avatar
Toby-22
Come at me brah!
19x9.5 +7 and 19x10.5 -6 with 265/30 and 285/30............................and -2.4 camber
Old May 21, 2011 | 09:54 AM
  #2109
Toby-22's Avatar
Toby-22
if you do have 275 then i think you belong here. Most of the cars here are the ones that don't belong, weak offset wheels with oversized tires with 2" fender gap
im going back to stretch myself once again, fat tires + super aggressive offsets dont really mesh well. My tires have been rubbing my rear bumper
Old May 21, 2011 | 10:49 AM
  #2110
Ak48z's Avatar
Ak48z
super lol
Old May 21, 2011 | 11:08 AM
  #2111
Max-G's Avatar
Max-G
troooooollllllin
typo????? had 265's on it before. just put 275's on.
Old May 23, 2011 | 07:26 AM
  #2112
scotts300's Avatar
scotts300
I'd rather my big tires, big grip, and no rub then your rubber band tires that rub all over the place. Yeah, that's fun. You probably bottom out on your shocks as well, which always makes for predictable handling. Your 285/30/19 is also 1" shorter than stock, which makes your speedometer useless.
"Going back to stretch" - cool. Bye.
Old May 23, 2011 | 07:38 AM
  #2113
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by scotts300
...I'd rather my big tires, big grip, and no rub...
sorry about hi-jacking your tire/auto x thread...thanks for the inputs!
...My tires have been rubbing my rear bumper...
can't leave me in here...
I'm looking to pushing it to the limits
18x9.5 +15 (18.6lbs) 15mm spacer 275/35R18 (25lbs) = 43.6lbs
19x10 +22 (21.3lbs) 25mm spacer 285/35R19 (29lbs) = 50.3lbs
I see it in my head
Awesome
should fix the gap in the front!
thoughts?
Old May 23, 2011 | 07:46 AM
  #2114
Toby-22's Avatar
Toby-22
305 up front and 315 rear is not good for such a low powered car. Thats actually slowing you down. Only place thats good for is autox which only a handful do in this thread.
But yea no reason to argue again, i forgot this is the Maximum Performance thread. Might as well post some print outs of your times, i'd rather see that than all these wheel gaps and oversized tires
Old May 23, 2011 | 07:47 AM
  #2115
scotts300's Avatar
scotts300
thoughts?
Happy to help any time. Without a lot of front camber and re-rolling the already-rolled front fenders, there is no way the 9.5 +0 will work with the 275. The 9.5 +15 with a 275 barely fits (with camber). Another 1/2"+ pushed out will require pinching the front fender roll even more, and probably 3.5-4^ of camber. Thankfully, you can buy/resell spacers, although you'll have to keep paying that silly shipping charge to the island. You can also start cheaply by buying a pair of 5mm slip-on shim spacers. Use one at first to see the clearance (or lack of!), then add the second one on the same wheel just for the fitment test. If all looks ok, then you can order the 15mm bolt-on spacer.
Old May 23, 2011 | 07:48 AM
  #2116
Toby-22's Avatar
Toby-22
I see it in my head
Awesome
thoughts?
haha your crazy man, i think your car looks perfect as is. But hey do what you want, judging from your car only advice you need is from you
Old May 23, 2011 | 08:35 AM
  #2117
KingBaby's Avatar
KingBaby
Hardest Setting
Happy to help any time. Without a lot of front camber and re-rolling the already-rolled front fenders, there is no way the 9.5 +0 will work with the 275. The 9.5 +15 with a 275 barely fits (with camber). Another 1/2"+ pushed out will require pinching the front fender roll even more, and probably 3.5-4^ of camber...
so you think with me being at 245/40R18 18x9 +5 I should just up the size of the tire?
it's not all about looks...I go!
it's alright... still can't park next to your car with those VOLKs
Old May 23, 2011 | 08:56 AM
  #2118
scotts300's Avatar
scotts300
The guy I got my NISMOs from ran a 265/40/18 up front. You could go 275/35 as well, though I doubt you'd be able to keep the 25mm spacer. You could change to the 18/19 RPF1 combo, I just don't think you can put the 15mm spacer on there to net a 18x9.5 +0 tire without some work.
Old May 23, 2011 | 09:08 AM
  #2119
SQBassHead's Avatar
SQBassHead
Toby- I liked your 305's better .... Sux ur going back to stretch , but if it means anything, you did give me the confidence to throw spacers on my 305's
So my setup is now
20X10 +10 with 305-25
Too bad I f'k up and had my fenders shaved... Bc now I can't pull the stupid fender FML! Now I have to get a body shop to re-weld and all that bs
Old May 23, 2011 | 09:20 AM
  #2120
SQBassHead's Avatar
SQBassHead
18x9.5 -13 235/40
18x10.5 -6 275/35
looks good bro
I say you DO belong in this thread..... One reason only
The standards we have in here are nowhere as high as the stretch thread
Don't be mad guys, bc you know its the truth
