Official Aggressive Wheels & Fat Tires Thread
Old Jul 7, 2011 | 02:29 PM
  #2221
03threefiftyz's Avatar
03threefiftyz
I forgot to take the spacer off as I test fit the first wheel......had one of those oh poop moments when I saw how far it stuck out. I would have had to run enough camber to make the hellaflush guys go whoa! I still hope to run a 12" wheel and 315's for Nationals next year . Some fender work will be required.
Old Jul 7, 2011 | 07:02 PM
  #2222
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Originally Posted by 2004Black350z
so its def my alignment. Since idk crap about suspension what should i make sure the shop thats doing my alignment? specs etc. Thx btw for replies
Old Jul 8, 2011 | 01:18 AM
  #2223
mjm26's Avatar
mjm26
have new wheels on the way. ccw c14's custom made with a step lip. should be done any day now. fronts are 18x11 and the rears are 18x12. cant remember the exact offset, i know i am sorry. but was planning on running 275 35 18 up front and not really sure about the rear. need suggestions. planning on a roll and mild pull. dont mind negative camber, it is not a daily driver. want the most grip as possible. leaning towards r888's or maybe a6's. makes 600whp on a dyno dynamics on pump. also coilover suggestions. thanks for your advice in advance.
Old Jul 10, 2011 | 11:36 AM
  #2224
GenX350z's Avatar
GenX350z
im usually on the stretch tires forum, but i recently built my block and upgraded to aps extreme twins. pushing 500+ and running on stretch tires isnt safe at all. i experienced that last night. so ive been looking at wheels with higher offsets. im planning to pick up those forgestars that are for sale, 19x9/11 +24 with 255/40/19 & 305/30/19. they came off a 370z, will they fit my 350z?? renders are rolled and pulled. my ride height is like inches off the ground. i wouldnt mind raising the car up for tire clearance. i just wanted to see if those specs would fit with no rubbing issues.
Old Jul 10, 2011 | 01:08 PM
  #2225
dkmesa350z's Avatar
dkmesa350z
camber is the only setting that has much flexibility depending on your needs. Around -1.5 f/r seems like a good balance of performance and tire life. Closer to -2 if you care less about tire life, closer to -1 if you want your tires to last longer. Caster, toe, etc. you are probably best letting them put them in the middle of the acceptable ranges unless you are trying to tweak your suspension for competition.
Old Jul 10, 2011 | 02:09 PM
  #2226
0jiggy0's Avatar
0jiggy0
When u **** with your camber to be herra frush etc. You destroy your tires. You want your tires to last? Run stock specs.
Old Jul 10, 2011 | 03:42 PM
  #2227
Ak48z's Avatar
Ak48z
pretty similar to my setup, I run 255/35 up front though, a 40 seems awefully tall with the 30 in the back, depends on the tire though.
If your fenders are rolled and pulled you will be fine. Might be able to get away without being pulled but you already are.
Old Jul 10, 2011 | 04:06 PM
  #2228
G4nismo's Avatar
G4nismo
nothing big
245/35/19
275/35/19
Old Jul 10, 2011 | 04:36 PM
  #2229
AroundMyHorn's Avatar
AroundMyHorn
Monster Truck Z!
Old Jul 10, 2011 | 06:04 PM
  #2230
dkmesa350z's Avatar
dkmesa350z
Originally Posted by AroundMyHorn
Monster Truck Z!
was thinking the same thing...holy crap needs a drop
Old Jul 10, 2011 | 06:30 PM
  #2231
lgear080's Avatar
lgear080
maybe it's a wrx setup
Old Jul 10, 2011 | 08:45 PM
  #2232
GenX350z's Avatar
GenX350z
Here we go, my first meaty set up. Picked up some Forgestar F14 19x9/11 the guy i bought them from (nismofo) had 255/40 in the front and 305/30 in the rears. i didnt understand the tire combo, cause a 40 series is a bit more from a 30 series. i have to ride with vdc off. that 305 is holding up 500+rwhp. thats the main reason why im running these. but here you go..
Old Jul 11, 2011 | 07:22 AM
  #2233
scotts300's Avatar
scotts300
255/35 front would satisfy the VDC with the 305/30 rear, or 265/275/30.
Old Jul 11, 2011 | 09:12 AM
  #2234
GenX350z's Avatar
GenX350z
appreciate the tip. i went ahead and went with 245/35/19. i dont know if thats too small of a size to run with 305's but its holding up so far. should be safe right?
Old Jul 11, 2011 | 09:42 AM
  #2235
scotts300's Avatar
scotts300
A little narrow for a 9" wheel in my book, but it's not uncommon and will make VDC happy.
Old Jul 11, 2011 | 03:55 PM
  #2236
512_Z's Avatar
512_Z
Monster Truck Z!
LOL
Old Jul 11, 2011 | 05:03 PM
  #2237
Total D's Avatar
Total D
Well I finally was able to change setups. I have gone from the 18s to 19s.
VOLK GT-S
19x9.5 +17 255/35/19
19x10.5 -2 285/35/19
I will be putting coilovers on in the next week or so. So for right now the Eibach Pro springs will have to work. Any suggestions will be appreciated.
Here you guys go.
Jeremiah
Old Jul 11, 2011 | 05:55 PM
  #2238
lgear080's Avatar
lgear080
nice work j - repost when you lowr
Old Jul 11, 2011 | 06:02 PM
  #2239
03threefiftyz
........big tires + soft suspension (shocks are being rebuilt at the moment) = big time body roll.
Old Jul 11, 2011 | 10:41 PM
  #2240
Total D's Avatar
Total D
Thank you Sir I will post them up. Waiting on the KWs then I will have a better looking stance.
