Official Aggressive Wheels & Fat Tires Thread
Old Feb 24, 2012 | 12:29 PM
  #3181
IsDatIt's Avatar
IsDatIt
Originally Posted by SoCal07HR
Looks real nice!
Thank You
Old Feb 24, 2012 | 04:05 PM
  #3182
Pete5150's Avatar
Pete5150
^^2+ Nice Setup IsDatIt!
Old Feb 24, 2012 | 06:51 PM
  #3183
4SHIZZIL's Avatar
4SHIZZIL
+3 nice indeed
Old Feb 24, 2012 | 10:57 PM
  #3184
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by IsDatIt
3rd Set!! lol
19x9.5+22 (265/35/19)
19x11 +25 (295/30/19)
Michellin Ps2
Any more pics??? Suspension specs? Just ordered a set of HRE with same specs except +20 front offsets. Looking to run 265/30 & 305/30 tires.
Old Feb 25, 2012 | 09:11 AM
  #3185
IsDatIt's Avatar
IsDatIt
Thank You Guys I Really Appreciate the Comments!
Ill Take Some More Pics Today Once i Install My 06+ Led TailLights and take her a Bath.
Just Running Tanabe GF210's With My Rear Fenders Rolled. You'll Be Fine With the 305's!!
Old Feb 26, 2012 | 01:16 PM
  #3186
Zgrabin's Avatar
Zgrabin
Originally Posted by 4SHIZZIL
mounted the 305/35/19s from my rear to the front (370z 19 rears) with no issues (no spacer +33) I didnt drive it, just a quick test fit. Now running a 275/35/19 on the 10 inch wheel for the front. 305/35/19 on a 10 inch wheel for the back.
So the second set of 370z rims was ordered to get 19x10s on all fours (no spacers front, 20 mil rear) (See attached pic) Before and After RIP Rice Version. Ill miss you! LOL Rice version had 20x9.5+13F (255-30) 21x10.5+17R (295-25)
sold the 4 19x9.5 to G37X sedan owner
Next sending the 19x10s off to get widened to 19x12 or 12.5 (havent decided yet) next week.
345/30/ Nitto Invo 19s are in route also.
Cant wait to claim 300s on all fours for my G35. Simply for bragging rights and to launch this 22 supercharged PSI beast to aircraft speeds in the 1/4 on street tires!
Stay tuned!
nice to know you admit your last look was rice..
Was not a fan at all..
but i'm in love with your new set up seeing as i have blue G as well and love the clean aftermarket factory version G.. like a AMG or M series for the G
just constructive criticism
Old Feb 26, 2012 | 04:17 PM
  #3187
4SHIZZIL's Avatar
4SHIZZIL
Well its a company car now so yo write it all off complete car must but advertisement. I think it qualifies. Wrote off over 15k in 2010!
It wasnt a daily then, its life sat at MMA UWC events at the Assassin Industries booth!
Tshirt graphics company, rice is perfect!
Old Feb 26, 2012 | 05:40 PM
  #3188
SoCal07HR's Avatar
SoCal07HR
^badass. Did you decide between 12 and 12.5 inchers out back? That's going to be poking out the fenders a lot, no? When will the wheels be widened? Can't wait to see it.
Old Feb 26, 2012 | 07:09 PM
  #3189
4SHIZZIL's Avatar
4SHIZZIL
^ look at post 3156, all I am doing is adding "under the car"
I have about 4 inches to spare if my calculations are right. But just incase. I do have a 20mm spacer on now with ARP Studs. I can go another 5mm out if I need to. But because I AM NOT running Coilovers. I have about 2 more inches of room than most set ups.
car will look just as it does now. going from a 305 to a 345 is just over 1.5 inches wider (under the car), so going with the 12.0 Rear!
Stock Tire - 305/35R19 Tiire 1 - 345/30R19 Search Tires
305 Section Width: 12.00 in 305 mm currently on a 10.0 inch rim
345 Section Width: 13.58 in 345 mm so the 12.0 should handle this OK
305 Rim Diameter: 19 in 482.6 mm
345 Rim Diameter: 19 in 482.6 mm
305 Tire Rim Width Range: Unrecognized tire size.
345 Tire Rim Width Range: 12 - 13.5 in
305 Overall Diameter: 27.40 in 695.96 mm
305 Overall Diameter: 27.14 in 689.35 mm shorter is better for running OEM camber.
305 Sidewall Height: 4.20 in 106.68 mm
345 Sidewall Height: 4.07 in 103.37 mm again shorter is better
305 Radius: 13.70 in 347.98 mm
345 Radius: 13.57 in 344.67 mm
305 Circumference: 86.07 in 2186.1 mm
345n Circumference: 85.26 in 2165.6 mm
305 Revs per Mile: 759.1
305 Revs per Mile: 766.3
305 Actual Speed: 60 mph 100 km/h
345 Speedometer1: 60.5 mph 100. km/h VDC will be happy!
takes 4 weeks due to volume so I should have the rears back somewhere around April 5th time frame.
so those that are running +5 offsets are 1 inch+ of thier wheel "under the car" more than my +33s.
flat face (rims), makes smilely faces when you can keep up with CBR 900s off the line! LOL
Old Feb 26, 2012 | 08:38 PM
  #3190
SoCal07HR's Avatar
SoCal07HR
As your suspension compresses the wheel arcs closer to the shock. So they will be 19x12 with what offset after your spacer?
Old Feb 27, 2012 | 01:10 AM
  #3191
Midnight_Slide's Avatar
Midnight_Slide
Im looking for a lil advice.
I want a meaty set up that fills in as much wheel gap as possible in the wheelwell.
Im currerntly running:
Mirro 111's
19x9.5 +20 Up Front
19x10.5 +20 in the rear
Im looking for meaty tires.
Like Best to fill the gap
these pictures arent showing for some reason so I am just posting the links
https://fbcdn-photos-a.akamaihd.net/..._4982777_a.jpg
https://fbcdn-sphotos-a.akamaihd.net..._5762612_n.jpg
Last edited by Midnight_Slide; Feb 27, 2012 at 01:12 AM. Reason: Pictures wont show
Old Feb 27, 2012 | 02:04 AM
  #3192
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Mirro 111's
19x9.5 +20 Up Front
I'm not the best person on this subject however the research I found for my newest wheel purchased; 19x9.5 +20 & 19x11 +25, I've opted for a 265/30 & 305/30. Here is a good wheel/tire calculator that lets you tr different sizes; http://www.rimsntires.com/rt_specs.jsp I have a feeling you'll be happy with a 255/35 & 285/35.
Old Feb 27, 2012 | 03:43 AM
  #3193
Midnight_Slide
Ah okay. I see. So I could fit 295's on a 10.5 inch wide rim
but what about height?
with 19's, would 40 be too much?
Old Feb 27, 2012 | 04:10 AM
  #3194
-Trav-'s Avatar
-Trav-
^Yes, a 295/40/19 would be plain silliness
  #3195
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Again, some of these other members have better knowledge/experience than I do. I do know that 295's are hard to come by. Also I've never seen a 40 series on a 19" wheel.
For your 19x10.5 +20 a 285/35/19 would;
~ 10 mm (0.4'') closer to suspension/brakes components.
~ Will stick out 30 mm (1.2'') farther.
~ Will fill out the wheelwell by extra 3 mm. Almost no difference.
~ When speedometer reads 60mph (96.6km/h) actual speed will be 60.5mph (97.4km/h): 0.8% faster.
For a 305/30/19;
~ 20 mm (0.8'') closer to suspension/brakes components.
~ Will stick out 40 mm (1.6'') farther.
~ 100% clears wheel well.
~ When speedometer reads 60mph (96.6km/h) actual speed will be 59.1mph (95.2km/h): 1.5% slower.
Old Feb 27, 2012 | 09:09 AM
  #3196
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old Feb 27, 2012 | 10:45 AM
  #3197
SDGenius's Avatar
SDGenius
^hahahahahahah
Old Feb 27, 2012 | 01:56 PM
  #3198
Midnight_Slide
For a 305/30/19;
285/35/19 is what I have on it now in the rear.
is it possible to get 295/35/19 fit the rear wheels?
and when I mean fill up the wheel well, I mean the gap that either makes it look dumped or monster truck statuss
Old Mar 3, 2012 | 07:07 PM
  #3199
SDGenius's Avatar
SDGenius
Old Mar 3, 2012 | 07:31 PM
  #3200
Looch's Avatar
Looch
^ oh my
