Official Aggressive Wheels & Fat Tires Thread
Old Dec 23, 2012 | 09:21 AM
  #4401
timmywhatsup's Avatar
timmywhatsup
Does anyone know if 305/30/19 RS3's work on the 19x10 Grand Touring wheels? Recommended is min 10.5 wide wheel. It appears 295/30/19 is the consensus for this wheel, but Im curious if that's the tipping point? They will see track time and need to remain functional. I don't mind if they bulge a little.
Old Dec 23, 2012 | 10:16 AM
  #4402
03threefiftyz's Avatar
03threefiftyz
I wouldn't want more than a 285 on a 10" wheel...
Old Dec 24, 2012 | 05:15 AM
  #4403
06z33's Avatar
06z33
Originally Posted by Robert_K
Think I'm going to stuff a R888 315/30 on my 11's whenever the time comes for new tires. I foresee it soon as I have yet to drive my Z with it's new found power.
I have 315/30 R888's....Makes your wheels look like monsters in the back and grips extremely well (once heated up) but they wear out pretty quick.
Old Dec 24, 2012 | 06:17 AM
  #4404
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Any pics?
Old Dec 26, 2012 | 10:56 AM
  #4405
06z33's Avatar
06z33
Any pics?
https://my350z.com/forum/wheels-and-...ml#post9797706
https://my350z.com/forum/wheels-and-...ml#post9904619
Its the vsxx. I posted some pics a while ago. I bought a 2011 sti recently and haven't really got back into the z for a little while. I'll get some better pics later on in the week if you want. The car has a do luck wide body kit though so fitment would obviously be different depending on your wheel width and offset. But the tires will still looks bad *** IMO
Old Dec 26, 2012 | 06:45 PM
  #4406
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I remember now. I actually went looking today and sadly found out that 315/30 R888 are not offered in 19's.
Old Dec 27, 2012 | 08:31 AM
  #4407
AT1222's Avatar
AT1222
Default tires
My wheels I will be ordering shortly are 19x9.5 +20 Front and 19x11 +18 Rear, I want as much traction as possible for drag and auto-x racing and know I will be rolling my rear fenders.. Should I get either 305 or 295 rear? and 265 or 275 front? And what sidewall ratio for these would keep tcs and speedo happy? Trying to figure out the exact size I need so I can pick out and order tires. I will eventually be lowering the car on coilovers preferably and getting the whole camber/toe kit as well to bring everything back into alignment. so any thoughts or suggestions?
Old Dec 27, 2012 | 09:29 AM
  #4408
terrasmak's Avatar
I would look into 275/30 front and 295 or 305/30 rears. Best bet is to not get the 19's and order a set of 18's
Old Dec 27, 2012 | 09:42 AM
  #4409
06z33's Avatar
06z33
Yea I used to have 19's as well with a 305 tire (thought I was hot **** back then lol) but the next size up is like 325 I think. It sucks.
Old Dec 27, 2012 | 11:34 AM
  #4410
4SHIZZIL's Avatar
4SHIZZIL
345/30/19 were test fitted. I can run them with neg camber, but at $600 per tire I prefer not too. I got the wrong daum size anyways. They should of been 345/25/19s.
Ill post pics in a few.
once I off load the 30 series, ill get the 25s and rock those...
NOTE: I drive a G35
Old Dec 27, 2012 | 09:10 PM
  #4411
scotts300's Avatar
scotts300
My buddy's DD wheels are a set of Volks in 9.5/10.5. He uses them as back-up tires for ax and track when the weather isn't conducive for his 18" R888s. I set him up with a set of 275/305/19 RS3s. Best decision ever, IMO. Not cheap though. The RS3s are actually faster in AX for most of our local courses.
Old Dec 28, 2012 | 05:21 AM
  #4412
4SHIZZIL's Avatar
4SHIZZIL
Default 345/30/19 test fit
the comparison tire is a 305/30/19 to the 345/30/19 like I posted earlier the correct size should be a 345/25/19.
running a widen 19x10 +33 offset 370z rim, I added two inched to the inner part of the barrel.
this made the 19x12
with a 20 mil spacer the tires slightly rubbed the inner part of my shock, NO COILOVERS
with a 25 mil spacer, the tire slightly rubbed the outter part of my fender. Now I can easily run a degree of neg camber to make this work, however I dont want to chew this tire up in 3K miles running 550rwhp. So I prefer to run OEM camber specs on all my tires, especially $600 ea tires. lol
this is awesome news because the 345/25/19 is not only almost an inch shorter, its also .5 or so less wide. I can run the 20 or 25 (prob the 25 to avoid shock run on hard launches) easily with the right tire.
this was an expensive test, I hope that this proves one can run a 345 on a G35 and shut up the na sayers.
enjoy the pics. Stay tuned for the 345/25/19s in actions.
Thanks goes to Hills Garage for taking time out of their day to do a simple test that took about an hour and a half, after driving the car around the parking lot, and remounting and rotating (flip inside to outside) my 305s at the same time!
305/30 vs 345/30
275/30/19 front
305/30/19 rear
soon
305/30/19 front
345/25/19 rear
ohh and 700 rwhp on C16 race gas
File Type: jpg
Old Dec 28, 2012 | 06:32 AM
  #4413
andypants101's Avatar
andypants101
Default TSW interlagos
18x8.5 with 245/45/18 Michelin pilot sport
18x10 with 275/45/18 M.P.S.
I need some suspension work lol... just got GF210 tanabe springs just need some new blue tokicos and im good
Old Dec 28, 2012 | 10:46 AM
  #4414
Waiz's Avatar
Waiz
That's not even remotely aggressive enough for this thread, in fact you're undersized for a 10" rear
It's a classy setup just doesn't belong in this thread
Old Dec 28, 2012 | 11:34 AM
  #4415
WhiteOnWhite350z's Avatar
WhiteOnWhite350z
NOTE: I drive a G35
http://www.tirerack.com/tires/tires....=yes&tab=Specs
Old Dec 28, 2012 | 03:09 PM
  #4416
805350z's Avatar
805350z
dat g35 0.0
Old Dec 28, 2012 | 04:34 PM
  #4417
JaE35z's Avatar
JaE35z
That G is a beast...more pics lol
Old Dec 30, 2012 | 12:53 AM
  #4418
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by WhiteOnWhite350z
Yeah i saw that. Sigh... They are being discontinued i hear? Either way too big of sidwall for my taste, i might run them if i cant sell.
Old Dec 31, 2012 | 08:43 AM
  #4419
RAntunes's Avatar
RAntunes
this is my first project and also the first time i bought/calculated my wheel & tire combo, you can do wonders with a backspace and wheel divider calculator,maybe this will be helpful to some guys here.
unless some extensive work is done to the fenders im pretty sure this is as wide it can go with "useful" camber.
specs are as follows:
18x10 +24
18x12 +22 (+37 barrel with a +15mm spacer)
toyo r888's
front: 295/30/18
rear: 315/30/18
r888's are gynormous and run almost an inch wider than what their website says, i planned ahead on my offsets.
my suspension is fully stock except MR street coilovers, when i dropped the car
my tire to fender clearance was perfect all around. ( which i planned on )
havent aligned it yet so i dont know my camber, but it looks acceptable. so i will adjust toe front and rear to 0 and keep stock arms and everything else all around. camber should be very close to stock.
the only "adjustments" were the removal of the screw that holds the fender liner in the front, and bent in the tab that holds it, and a fender roll with no pull in the rear ( done with a heat gun and a bat )
the front clears the control arm by 2mm, and the fender with 2mm when fully compressed, the rear clears inside and out with about 2mm as well.
some pics of clearance and fitment ( excuse the mess around, and the car's appearance, its an on going project.) hope its useful!!
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-front-inner-fender.jpg   Official Aggressive Wheels & Fat Tires Thread-front-fender-clearance.jpg   Official Aggressive Wheels & Fat Tires Thread-front-fit.jpg   Official Aggressive Wheels & Fat Tires Thread-rear-inner-full-compression.jpg   Official Aggressive Wheels & Fat Tires Thread-rear-fender-roll.jpg
Official Aggressive Wheels & Fat Tires Thread-rear-fender-fit.jpg   Official Aggressive Wheels & Fat Tires Thread-rear-camber-shot.jpg   Official Aggressive Wheels & Fat Tires Thread-rear-side-shot.jpg   Official Aggressive Wheels & Fat Tires Thread-side-shot.jpg
Old Dec 31, 2012 | 09:01 AM
  #4420
redline06's Avatar
redline06
holy tittiesprinkles that is sick awesome first post lol
