Official Aggressive Wheels & Fat Tires Thread
Old Apr 24, 2013 | 12:30 PM
  #4661
nismonian's Avatar
nismonian
pics?^
Old Apr 24, 2013 | 01:01 PM
  #4662
the3kgt2's Avatar
the3kgt2
Originally Posted by nismonian
pics?^
This was with 275/40/18 front and 295/35/18 rear. I'm curious if I can fit 285/35/18 front and 305/35/18 rear.
Old Apr 24, 2013 | 01:11 PM
  #4663
taryon's Avatar
taryon
^ nice car man, but I do believe that your front tires are bigger than your rears
EDIT: nvm you have a new setup now
Old Apr 24, 2013 | 04:10 PM
  #4664
terrasmak's Avatar
Originally Posted by the3kgt2
This was with 275/40/18 front and 295/358/18 rear. I'm curious if I can fit 285/35/18 front and 305/35/18 rear.
YOu can, but i would want a 10.5 up from for a 285
Old Apr 24, 2013 | 05:17 PM
  #4665
the3kgt2's Avatar
the3kgt2
According to Hankook, a 285/35/18 R-S3 will fit a 9.5" wheel just fine.
<table class="spectable" border="0" cellpadding="0" cellspacing="0"><thead><tr><td align="left">Size
Service Description
Load Range</td> <td>UTQG</td> <td>Max
Load
</td> <td>Max.
Inflation
Press.
</td> <td>Tread
Depth
</td> <td>Tire
Weight</td> <td>Rim
Width
Range
</td> <td>Meas.
Rim
Width
</td> <td>Sect.
Width
</td> <td>Tread
Width
</td> <td>Overall
Diam.
</td> <td>Revs
Per
Mile
</td> <td>Country
of Origin*
</td> </tr> </thead> <tbody><tr> <td width="190">285/35ZR18
101W XL </td> <td align="center"> 200 A A </td> <td align="center">1819 lbs.
</td> <td align="center">50 psi
</td> <td align="center">8.8/32"
</td> <td align="center">30 lbs. </td> <td align="center">9.5-11"
</td> <td align="center">10"
</td> <td align="center">11.4"
</td> <td align="center">10.1"
</td> <td align="center">25.9"
</td> <td align="center">803
</td> <td align="center"> KR </td></tr></tbody></table>
Old Apr 24, 2013 | 07:20 PM
  #4666
terrasmak's Avatar
Service Description
Load
</td> <td>Max.
Inflation
Press.
</td> <td>Tread
Depth
</td> <td>Tire
Weight</td> <td>Rim
Width
Range
</td> <td>Meas.
Rim
Width
</td> <td>Sect.
Width
</td> <td>Tread
Width
</td> <td>Overall
Diam.
</td> <td>Revs
Per
Mile
</td> <td>Country
of Origin*
I would do 10 minimum, it is a wide tire and fits perfectly on my 10.5's.
Old Apr 24, 2013 | 08:42 PM
  #4667
the3kgt2's Avatar
the3kgt2
Thanks terramask, but I already own my wheels. I was asking if a 285 will fit my 9.5" fronts without rubbing...not if I should replace my wheels.
Old Apr 24, 2013 | 09:00 PM
  #4668
scotts300's Avatar
scotts300
I have run 285 RS3s on the front with a few set-ups. What's the offset of your 9.5?
Old Apr 24, 2013 | 09:21 PM
  #4669
the3kgt2's Avatar
the3kgt2
They're +15
Old Apr 25, 2013 | 08:26 AM
  #4670
scotts300's Avatar
scotts300
They're +15
It's tight and looks good, but you may get a little scuffing here and there but not bad. I had good camber, 3.2ish degrees, in this pic, and the car was really low, but no major issues.
Attached Thumbnails Official Aggressive Wheels &amp; Fat Tires Thread-132855_10151167928043805_1510505027_o.jpg
Old Apr 25, 2013 | 08:53 AM
  #4671
the3kgt2's Avatar
the3kgt2
That does look good (and very tight) but you're running a lot more camber than I am. Are your front fenders rolled or cut? Since I currently have my 285's mounted on my rear 10.5" wheels, I might try swapping the wheels up front to see if they rub before mounting them on my 9.5" wheels.
Old Apr 25, 2013 | 09:01 AM
  #4672
scotts300's Avatar
scotts300
No rolling done. You can test fit with the 10.5s, but you'll have more overall width and tire geometry than the 9.5s.
Old Apr 25, 2013 | 09:08 AM
  #4673
the3kgt2's Avatar
the3kgt2
Thanks, Scott! If they don't fit I'll just buy some used 275/35's from you. You're practically a used Hankook dealer.
Old Apr 25, 2013 | 09:20 AM
  #4674
03threefiftyz's Avatar
03threefiftyz
A 285 RS3 really works best on a 10.5-11" wheel, but you can easily run it on a 9.5" if so inclined.
Old Apr 25, 2013 | 09:31 AM
  #4675
fairladyboss's Avatar
fairladyboss
295/35/18 back 265/35/18 front
Old Apr 25, 2013 | 10:01 AM
  #4676
KingBaby's Avatar
KingBaby
Hardest Setting
soo nice...
Old Apr 25, 2013 | 10:09 AM
  #4677
scotts300's Avatar
scotts300
I actually like the fit of the 265 on the 9.5. Plus, I don't have 275s but do have 265s to pass on.
Old Apr 25, 2013 | 10:51 AM
  #4678
the3kgt2's Avatar
the3kgt2
I'm understeering with my 265 fronts. My car is extremely front heavy with the Vortech and gutted trunk...otherwise I'd keep my 265s.
Old Apr 25, 2013 | 02:06 PM
  #4679
scotts300's Avatar
scotts300
PM or email me. I have 9.5 +15s with the 285 RS3 on them.
Old Apr 26, 2013 | 07:09 PM
  #4680
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Just wanted to share my Forgeline's shipped today! TIA.
