Official Aggressive Wheels & Fat Tires Thread
Old Apr 26, 2013 | 07:51 PM
  #4681
KingBaby's Avatar
KingBaby
Hardest Setting
Copying fairladyboss side profile shot...
Old Apr 26, 2013 | 08:00 PM
  #4682
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Originally Posted by fairladyboss
295/35/18 back 265/35/18 front
Well done sir
Old Apr 26, 2013 | 08:03 PM
  #4683
SE5spd's Avatar
SE5spd
The3kgt: why not get 10.5 F/R and run 285 RS3 square?
thats what im gonna do soon. Thats the way to go when you get faster.
Old Apr 28, 2013 | 01:10 PM
  #4684
AlexBG's Avatar
AlexBG
I got the 265/35 and 295/35 Nitto NT05's mounted on my 18x10 +14 and 18x11 +14 Work Bersaglio's
I still need to adjust the height on the front. I got the rears dead on.
Camber is OEM Spec at the moment.
I will take better picture once the front is down and have it aligned.
Before:
235/35 and 245/35
Camber -2.7 Front -3.8 Rear
Old Apr 29, 2013 | 06:16 PM
  #4685
zleeperZ's Avatar
zleeperZ
front:275/?zr19 rear:305/30zr19
tire: Michelin pilot super sport
rim: Volk RE30 19x10 and 19x11 GTR offsets that shariff recommended for my bosses gtr
sits flush. -1.5 camber in the rear and -1.2 in the front.
i had to roll the rears with a very slight pull and the fronts are pulled significantly but i dont rub whatsoever.
sorry for the quality of the photos. i upload from my phone.Name:  20130326_185602.jpg
here is a video of the rims in action.http://s43.photobucket.com/user/elec...1_001.mp4.html
Old Apr 29, 2013 | 09:42 PM
  #4686
terrasmak's Avatar
Sounds like someone is trying to set up a car to outrun me !!
Old Apr 30, 2013 | 03:30 AM
  #4687
NaughtyDawg63's Avatar
NaughtyDawg63
Trying to get some ideas here. Currently i am on 235/40/18 with 18x10.5s all the way around. Would like to ditch the stretch. My fronts and rears are rolled/pulled already. Really wanting a nice flush setup. Offsets are +10 front and -10 rear. Any help would be awesome.
Old Apr 30, 2013 | 07:47 AM
  #4688
terrasmak's Avatar
275/35-18 all around would be a good start. Are you running spacers ? If so, i would run a bit smaller rear spacer, probably only space it to 0. Also how much camber do you want to run, race alignment or mostly a street car?
Old Apr 30, 2013 | 12:23 PM
  #4689
scotts300's Avatar
scotts300
You are about an inch off in the rear offset assuming you go 275 or 285 square on that set-up. I'd pull the front in 5mm or so if possible as well.
Old Apr 30, 2013 | 03:32 PM
  #4690
NaughtyDawg63
I wouldn't mind camber. And yes there spaced. Without the spacers the offset is +20 all the way around. I wish the fenders weren't pulled. It would make this easier ha
Old Apr 30, 2013 | 03:53 PM
  #4691
03threefiftyz's Avatar
03threefiftyz
Won the SCCA Dover National Tour this weekend in BSP...even with the car breaking on the second run on Sunday ...
Old Apr 30, 2013 | 04:40 PM
  #4692
03threefiftyz
Uno mas...
Old Apr 30, 2013 | 07:30 PM
  #4693
SE5spd's Avatar
SE5spd
Going for mid 33s big willow my first time there, no areo, on street tires, with an sucky driver lol jk. Im on 275 on a 9.5" front now, so next time im going 10.5" on a 285 and ill have A arms to bump up the camber up front.
Old May 1, 2013 | 03:19 AM
  #4694
NaughtyDawg63
So what do you mean by my offset us off an inch? To low? And pull the front in? Its flared out now
Old May 1, 2013 | 06:04 AM
  #4695
STL 350Z's Avatar
STL 350Z
This is hawt!
Any pics of the rear and those wide *** 305's?
Old May 1, 2013 | 07:39 AM
  #4696
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by STL 350Z
This is hawt!
May 16-19 Ill be in STL. (assuming you are in St. Louis. lol)
hit me up on the 15th ill be free. Im in a wedding...
"BINDER" and I always try to link up.... he has a 600+ single turbo G.
Old May 1, 2013 | 08:37 AM
  #4697
scotts300's Avatar
scotts300
I have a bunch of good 285 RS3s if you need another pair. I bought stock in them last month and have 10.
Yes, too low. Pull the front in meant run less spacer as a 10.5 net+10 is pushing it with a 285 up front without a shat ton of camber.
Off by an inch in the rear because you'll need more offset with a 10.5 -10 and a 285. That's rub city unless you pulled it out an inch.
Old May 4, 2013 | 07:48 AM
  #4698
Cypher39's Avatar
Cypher39
I couldn't have said it better.
Old May 9, 2013 | 03:28 AM
  #4699
NaughtyDawg63
Yes,too low. Pull the front in meant run less spacer as a 10.5 net+10 is pushing it with a 285 up front without a shat ton of camber.
Off by an inch in the rear because you'll need more offset with a 10.5 -10 and a 285. That's rub city unless you pulled it out an inch.[/QUOTE]
ahhh ok. So the wheels are +20 offset without any spacers. So maybe keep the rear like that. Throw a 5mm slip on maybe front? 285/35?
Old May 10, 2013 | 12:19 PM
  #4700
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-foreglines.jpg
