Official Aggressive Wheels & Fat Tires Thread
Old Jun 16, 2013 | 04:48 PM
  #4801
Lubo's Avatar
Lubo
Terra is right. Camber is around -3.2* with about 1/16" toe out. The only street driving the car sees is when it is being driven from the garage to the events. Tire wear is nice and even across.
Originally Posted by kyle22
Man your fronts sit flush, what are your alignment specs? I have the same wheel but 18x9.5 255/35/18 front and they stick out past the fender
Old Jun 16, 2013 | 10:17 PM
  #4802
scotts300's Avatar
scotts300
Originally Posted by STL 350Z
so what's the deal with people saying that I'm going to lose functionality with 305's in the rear. nobody else in this thread has any problems do they?
Absolutely not. Not with 315 rears either, or 305 fronts for that matter.
Old Jun 17, 2013 | 06:16 AM
  #4803
STL 350Z's Avatar
STL 350Z
Then you need to come into my subreddit and school some people.
http://www.reddit.com/r/350z/comment...19_nitto_invo/
Old Jun 17, 2013 | 06:40 AM
  #4804
herrschaft's Avatar
herrschaft
Sounds like a bunch of people with low HP cars that don't have traction issues with skinny tires.
Old Jun 17, 2013 | 06:52 AM
  #4805
STL 350Z's Avatar
STL 350Z
They are internet hardasses that know everything. I hope this thread school's them...
Old Jun 17, 2013 | 12:06 PM
  #4806
-Trav-'s Avatar
-Trav-
Seems clear that they've never owned tires that wide and are making blind assumptions.
When I had my 265-295/30/19 I noticed the car was much more nimble and steering effort was reduced dramatically. Probably due to a bit more stretch up front than stock but the increased width didnt have a negative effect as many would say. After all was said and done even with the larger wheels and tires (came from stock 225/245) I was more or less breaking even on weight.
Tire brand has a lot to do with it though... looking at specs on TR the weight difference between a 225/45/18 and 275/30/19 can be anywhere from 1 to 4 lbs, which is quite significant (see Sumitumo HTR vs Michelin PSS).
Old Jun 19, 2013 | 07:19 AM
  #4807
ProXR 440's Avatar
ProXR 440
When I was trying to decide which wheel and tire size combo I wanted to go with last year I made this spreadsheet. I ended up going with the 10" front and 11" rear setup that is highlighted in yellow. All it takes is a little bit of research and measuring to figure things out. I had the OEM 18" chrome wheels and if I remember correctly they weighed more than my new 19" VMR's and these aren't lightweight wheels either. The new tire weights are the same as the stock size also. So my weights stayed the same or less, I have a lot more tire on the ground, the car rides and performs better, I can corner like a ****, and it looks better. That's my take on wide tires on a stock NA car...
Then plug all of those number into THIS! http://www.rimsntires.com/specs.jsp
Old Jun 19, 2013 | 08:02 AM
  #4808
ProXR 440's Avatar
ProXR 440
Before-
After-
Before-
After-
Test fitting before mounting tires-
This is how close it was before rolling my rear fenders. It rubbed going over the curb going in and out of my driveway and on big dips in the road going through intersections. Fronts have no issues.
Rolling-
Old Jun 19, 2013 | 09:24 AM
  #4809
Chi-TownWarrior's Avatar
Chi-TownWarrior
You sir have found another way to do it right. Looks good. Mind sharing your excel template?
Old Jun 19, 2013 | 09:51 AM
  #4810
ProXR 440's Avatar
ProXR 440
Thank you. How do you want me to share it? It's a Google Drive document right now. If you have a Google account I can share it that way. It's nothing fancy, what you see is what you get. I don't have any formulas setup in the spreadsheet if that's what you're looking for.
Old Jun 19, 2013 | 11:09 AM
  #4811
Chi-TownWarrior
I'll PM my info later. But I'll try to make a template and share it. Thanks.
Old Jun 19, 2013 | 01:49 PM
  #4812
zdaddy2008's Avatar
zdaddy2008
Ok so I installed the 275/30's on the front today. Removed the 255/35's, It looks way better. Perfect sidewall difference compared to the 305/30's out back. I guess I belong in the fat tire thread now. Lol
Old Jun 19, 2013 | 01:52 PM
  #4813
zdaddy2008's Avatar
zdaddy2008
Default New front tires
Oh yeah. Forgot the pics. I will post later. Car is filthy anyways.
Old Jun 19, 2013 | 04:54 PM
  #4814
SirMichael's Avatar
SirMichael
Finally get to post here.
Front 9.5x18+15 - 275/35/18s
Rear 10.5x18+15 - 295/35/18s
Severe rubbing in the rear, fends were partially rolled to begin with. Now its at Motorsport Authority getting them rolled further and the car repainted. Ill post more pictures when I finally have her back.
Old Jun 19, 2013 | 06:06 PM
  #4815
03threefiftyz's Avatar
03threefiftyz
Front control arms are not remotely BSP legal....just as an FYI. You also can't run a true rear coilover in BSP. Welcome to the wonderful world of SSM.
Old Jun 19, 2013 | 06:07 PM
  #4816
SirMichael's Avatar
SirMichael
I know, but I wasn't going to tell the guy he was wrong about the class. But thanks for the heads up on the class I should be in. Now I can get magnets made. I was curious which class I was supposed to be in. I have replaced all of the bushings except the sub frame bushing I decided to go a different route with them in the future.
Old Jun 19, 2013 | 06:16 PM
  #4817
03threefiftyz
SSM is the land of 3 rotor, big turbo 2 rotor RX7's with full aero. I'm one of the faster BSP guys around, and the top SSM cars walk me like a dog.
Carter Thompson (former 350z guy!) won SSM last year in this:
vs.
BSP 350z
Old Jun 19, 2013 | 06:22 PM
  #4818
SirMichael's Avatar
SirMichael
vs.
BSP 350z
Ouch! Oh well no turning back now. I'm not building it toward a specific class other than just building it for me.
Old Jun 20, 2013 | 11:24 PM
  #4819
CleanFairladyZ's Avatar
CleanFairladyZ
Hey guys, I was thinking about getting a new set of wheels. If I settle on 18x10 square, what would be a good offset? And I like a fat tire but not too much sidewall. What would be good tire sizes? and obviously some tires are made much wider than others, is there one I should point more towards? Also, I would like to be able to clear brembos. Thanks!
Old Jun 21, 2013 | 09:38 AM
  #4820
scotts300's Avatar
scotts300
+20 or so, with 285/35 Hankook RS3 tires
