Weird sound after adding aftermarket rims
Old Jun 9, 2009 | 05:18 PM
silver350zz's Avatar
silver350zz
Default Weird sound after adding aftermarket rims
Got the rims today, bought them from another member on here just got finished
putting them on, and then of course for me something goes wrong lol.
Everything is tight nothing is loose, yet when I drive, and get it up to around
30mph and let go of the gas as I am rolling, a sound coming from the FR tire
sounds like a bowling ball going down a lane? Maybe a rotor problem? Or a bad
tire? Never had the noise with the stockers on, rims are 20" Axis Shines.
Old Jun 9, 2009 | 05:37 PM
phreaktor's Avatar
phreaktor
Design Engineer
You probably just aren't used to being on an aluminum 20 inch wheel. I just got a set of DPE 19's and noticed the same thing. Check your tire pressures as well.
Old Jun 9, 2009 | 05:55 PM
silver350zz
Just something about hearing a sound that is that loud over the road noise doesnt seem
like I should be able to hear it..
Old Jun 9, 2009 | 06:35 PM
Welcome. Wheels are seldom the culprit. Tires are from a 350Z? See the feathering thread.
Old Jun 9, 2009 | 06:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Put the stock back on first and see if you hear ( make sure if it is aftermarket wheel )
Also it's good to check hub ring/centercap on wheel.
Old Jun 9, 2009 | 07:28 PM
silver350zz
I swapped the rims back to stock and heard no noise then back to aftermarket and noise, the rims are not warped or bent or anything, but they do weigh a ton lol. Im thinking that has something to do with it, it isnt feathering as far as I can tell and no vibrations except for the weird sound.
Old Jun 9, 2009 | 08:00 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I forgot but when i was shopping for my rims back in year ago... i heard that issue from members...I can not remember now but think was center cap or hub ring. God...man sorry man, can not think of.
Old Jun 9, 2009 | 08:15 PM
silver350zz
Ok well I am going to have a shop look at the wheel bearings, and hub ring tomorrow hopefully nothing major, I hate the negatives of mods lol
Old Jun 10, 2009 | 01:42 AM
Ziggyrama's Avatar
Ziggyrama
Sounds like tire roar. Did you buy new tires for these wheels or did the wheels come with tires? If you got them with wheels, is it a staggered setup? If so, for the purpose of the experiment, put the rears in the front and fronts in the rear and drive down the street. See if you're still getting the noise. If it goes away, the front tires are feathered or they're just very noisy. Some brands tend to be that way, especially as they wear on.
I remember my stock potenzas used to roar something fierce and they didn't even have much mileage on them. ~5000K. And that was on stock 17s. It's the tires, not the wheels. If the wheel was making contact with anything, you'd hear worse things than just roar.
Old Jun 10, 2009 | 04:26 AM
eminence978's Avatar
eminence978
yeah i had the same issues with my wheels, the shop forgot to torque my lugs right and didn't put on the hubcentric rings...sounded like my wheels were going to fall off.
Old Jun 10, 2009 | 06:34 AM
mD2MHK's Avatar
mD2MHK
haha lol... dangerous
Old Jun 10, 2009 | 06:45 PM
knils's Avatar
knils
holy sh*t... dangerous as all hell I hope you gave them an earful
Old Jun 10, 2009 | 06:59 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Ya man the noise from 20's on those low pro's will be more loud than stockies. But i dont know about "bowling ball" loud. +1 on checking your hub rings.
DID YOU PUT THE RINGS ON when you put your 20's on? Little black plastic rings alittle smaller than a round coaster?
And its not your wheel bearings if you dont hear the noise with your stockies.
Old Jun 11, 2009 | 01:08 PM
raf84ny's Avatar
raf84ny
I have the same issue with my 19s. The bad thing is the longer I drive it, the louder it gets. The tires were purchased used so I know I need new tires.
Old Jun 15, 2009 | 07:23 AM
silver350zz
ya just the user who i put the rims from had front tire feathering and was causing all the noise, I need to get some new front tires on it and it should be fine feathering FTL
Old Jun 17, 2009 | 10:14 PM
L33TZOR's Avatar
L33TZOR
A few years back i had a similar problem with some enkeis on my maxima. if they are not tightened manually and were put on with an air gun, that can do this... or the nuts dont tighten down all the way on these wheels or the wheels were not carefully centered when put on the car??
remove them, check the threads on the wheel studs. the ?hubcentric? rings i think they are called, someone pointed out, you may be missing them. the studs will eventually break if you dont take care of this. take your ride to a pro wheel shop or some wheel place you trust.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
