tires quick question
Old Jun 17, 2009 | 06:00 PM
bballgms's Avatar
bballgms
Default tires quick question
i have the stock 2005 17in rim and would like to get better tires right now the stock size is 225/50 and 235/50, would it be bad if i went to 225/45 and 235/45
wats the pros and cons.
Old Jun 17, 2009 | 08:41 PM
03brembo's Avatar
03brembo
slighty stiffer ride.
smaller side wall
how bout sell those and just get a whole new tire wheel set up
Old Jun 17, 2009 | 08:42 PM
michaeljr6's Avatar
michaeljr6
just stick with the 50.
Old Jun 17, 2009 | 08:47 PM
bballgms's Avatar
bballgms
the reason i want to go to the 45's is bc i want to get the pilot sport 2 and they dont come in 235/50 they come in 235/45.
Old Jun 18, 2009 | 05:35 AM
bballgms's Avatar
bballgms
also is speedometer rating from front or rear tires?
Old Jun 18, 2009 | 06:14 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Dude keep the tires you have, dont buy new tires for stockies just wait until you buy all new rims/tires. Trust me, youll regret spending the money when it comes to the time when you want new wheels.
Also, IF you do, dont get 45's, youll have a bigger gap in the wheel well and tires will look too small for the car.
Old Jun 18, 2009 | 01:08 PM
bballgms's Avatar
bballgms
the things is i need new tires my stock tires are goin bald. and i want to get good quality tires and i dont have that much money for a rims.
Old Jun 19, 2009 | 06:32 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Then go with the right sizes (50).
Old Jun 19, 2009 | 09:49 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
+1 ^^
Old Jun 20, 2009 | 12:19 PM
bballgms's Avatar
bballgms
also the eagle f1 asymetrics dont come in profile. thats why idk what i should do.
Old Jun 29, 2009 | 01:24 AM
bballgms's Avatar
bballgms
bump
would it be bad if i get the eagle f1 asymetrics on my 17in rim 225/45/17 and 235/45/17.
Old Jun 29, 2009 | 10:41 AM
neal@tirerack
Those are close to an inch shorter than what should be on there.
Old Jun 29, 2009 | 11:13 AM
GeauxLadyZ's Avatar
GeauxLadyZ
bump
Seriously? Why the hell are you still looking at tires that dont come in 50's??
Your fired.
Old Jun 29, 2009 | 04:35 PM
Spike100's Avatar
Spike100
It sounds as though your problem is the 17” wheels.
If you go with a shorter tire (the 45 profile) on a 17” wheel, you car will look retarded unless you drop it slightly. If you don’t have $$ for different wheels, you probably cannot afford new suspension components to do the drop.
Here is an idea: Shop around for stock 18 x 8” wheels (you can get these cheap from someone swapping for aftermarket wheels.). Michelin PS2’s are great tires, but they are very expensive. Consider a less expensive tire to keep within your budget for a 17” to 18” wheel swap. I’m sure Neal can suggest a good tire that is less costly than the Michelins.
245/40-18” front and 245/45-18” rear is a good choice that provides very fun handling.
Just a thought…
--Spike
Last edited by Spike100; Jun 29, 2009 at 06:58 PM. Reason: change to less profile on the front 18" tire
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
