Largest Tires for a Stock 03 Track?
Old 09-14-2009, 12:45 PM
dduck44
dduck44's Avatar
Default Largest Tires for a Stock 03 Track?
I noticed my tires are going to nedd replacing soon and was wondering what the widest and lowest aspect tire I can fit on my 03 track model without problems like rubbing or throwing the VDC off. I did a search and it looks like a 245/40/18 up front and a 275/40/18 in the rear. Is this a correct combination? Also, anyone have experience with the Hankook Evo V12 tires?
Thanks.
Old 09-14-2009, 01:38 PM
scotts300
scotts300's Avatar
245 is ok on an 8" wheel.
275 is larger than recommended for an 8.5" wheel.
Old 09-14-2009, 01:48 PM
DavesZ#3
DavesZ#3's Avatar
Had you searched you would have found that this has been discussed several times, include two in the last few weeks....
https://my350z.com/forum/wheels-and-...tire-size.html
https://my350z.com/forum/wheels-and-...rear-rims.html
https://my350z.com/forum/wheels-and-...installed.html
https://my350z.com/forum/wheels-and-...tock-rims.html
https://my350z.com/forum/wheels-and-...ck-wheels.html
Check on Tirerack, Discount Tire Direct and any number of tire dealer sites and you'll see that the widest recommend tire on a 8½" wheel is a 265.
Old 09-14-2009, 05:21 PM
Eddie@Performance
Performance Nissan
Eddie@Performance's Avatar
275 on a 8.5" looks sorta goofy. Id probably do a 235 front and 255 rear to keep sidewalls from looking like my beer belly.
Old 09-14-2009, 06:06 PM
Instead of a wider tire how about a better tire? In other words a superior 245 mm tire will outperform a mediocre 275 mm tire any day.
Old 09-15-2009, 08:04 AM
Eddie@Performance
Performance Nissan
Or a superior 275
Old 09-15-2009, 11:43 AM
neal@tirerack
Vendor - Former Vendor
neal@tirerack's Avatar
Nothing with the correct overall diameter that will fit those wheels. 265's and 275's require at least a 9". Not much you can do w/out new wheels.
Old 09-15-2009, 12:27 PM
PDX_Racer
PDX_Racer's Avatar
I've been running 275s on the stock track wheels for the past four years. They don't look goofy, nor do they look squeezed -- and I get really good tire wear as well.
Old 09-15-2009, 01:43 PM
scotts300
scotts300's Avatar
I respect your views, so I will simply ask what brand/model of tire? Maybe it is one that runs more narrow than others.
Old 09-15-2009, 01:49 PM
DavesZ#3
DavesZ#3's Avatar
Correct me if I wrong, but you're not daily driving/streeting those - isn't that for autocross only. I'm running 265s on track wheels, but for autocrossing. Sure they're squeezed on the wheel, that's why it's not recommended by manufacturers.
Old 09-16-2009, 12:32 PM
Boostedtrack350
Boostedtrack350's Avatar
Do you have any pics of the 275 on the track wheels? I have 265's now and dont think they look bad at all on the 2003 track wheels.
Old 09-16-2009, 05:33 PM
terps
terps's Avatar
ughh im going 285 on the stock 8.5 rear rim(bridgestone re11's), yah not recommended but im giving ti a shot, well see i got a tire dealer with alot of experience and he says it wont be a problem?
Old 09-16-2009, 07:49 PM
SnoXRacer183
SnoXRacer183's Avatar
Here are my 275 Goodyear Eagle F1s on stock 2008 rims (8.5" wide)
Old 09-16-2009, 09:25 PM
PDX_Racer
PDX_Racer's Avatar
Nope, 245/40R18 front and 275/40R18 rear, Kumho ASXs are my daily drive tires. 285/30R18 Kumho V710s or 295/30R18 Hoosier A6s are my autocross tire.
The front 245s are square on the wheel (and are a lot better than the 225s that were WAY too narrow). The rear 275s are only a bit wider than the wheel (maybe a total of 3/4 inch -- 3/8 inch per "side"), and unless you look really hard, you wouldn't really notice it. 265s would be "better" but don't discount 275s -- a 40-series tire has quite a bit of sidewall.
As another example, 285/30R18s are a pain to mount. 295/30R18s just about drop on all four wheels -- even the 8-inch.
Oh, and looking at the picture above, that's about what my 275s look like as well.
HoBrahYouStink
06-24-2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
SharX59
09-30-2015 10:54 AM
Quick Reply: Largest Tires for a Stock 03 Track?
