18x9.5 +15 with 275/35/18 Front -3 camber
Old Sep 22, 2009 | 09:55 AM
mistico's Avatar
mistico
Lightbulb 18x9.5 +15 with 275/35/18 Front -3 camber
I need new track wheels and need to know if I can fit 18x9.5 +15 Enkei RPF1 with 275/35/18 tires up front with -3 camber settings(with no fender roll). It would only be for track use(road course)
Some say it fits, some say it doesn't, so I don't want to pull the trigger until I'm at least 90% certain
Any input from people running this setup, similar setup or know someone running this setup?
I currently run 18x9.5 +22 but one wheel cracked and they have been discontinued, can't find one anywhere.
Thanks!
Old Sep 22, 2009 | 10:05 AM
mistico's Avatar
mistico
ok, got this from another thread.
Originally Posted by SOLO-350Z
Many here do 275 all around with track wheels/tires. And you can rotate them. I believe the size of the RPF1s are 18x10.5 with 15mm offset and 275 all around that everyone uses without a problem. Friend had it on his and no issues. I plan to get it as well.
Anyone else seen or used this setup successfully?
Old Sep 22, 2009 | 10:59 AM
zerafian's Avatar
zerafian
I dont see the big deal..put them on and if you end up needing to roll your fenders oh well...youll be happy you did it anyways
Old Sep 22, 2009 | 01:20 PM
BarefootRacer's Avatar
BarefootRacer
Im running a 10.5 plus 15 with a 265/35 up front with only -1.8 camber and i have my fenders slightly pulled. You should have plenty of space!
Old Sep 22, 2009 | 01:43 PM
mistico's Avatar
mistico
I don't want to pull the fenders.
I won't be going with this combo. Thanks though.
/Thread
Old Sep 22, 2009 | 02:23 PM
BarefootRacer
/Thread
You said you want to run a 9.5 15mm offset which is 1 inch smaller than what im running. This means you wont have to touch the fenders at all. They will fit the stock fenders perfect with no modifications!
Summary...
9.5 15mm offset w/ 275/35 fits stock fenders all day!
10.5 15mm offset with 275/35 will need a slight pull. (like a 1/4 of an inch)
Old Sep 22, 2009 | 03:55 PM
Chebosto's Avatar
Chebosto
i am running R888 265/35/18 (which is almost a 275) on a 18x9.5 +18 offset RE30 with -3.25 camber.
with room to spare.. although my cf fenders are 5mm wider than stock... but i think you should still be fine.
Old Sep 23, 2009 | 01:29 PM
mistico's Avatar
mistico
Thanks Chebosto.
I wrote above that I wouldn't go with these, but found a set in the size above and got them. I'll find out next week how they fit and will report back.
The main reason for going with RPF1's was weight. They only weigh 18.6lbs. I'll throw them on the scale just to confirm.
Old Sep 23, 2009 | 02:26 PM
Chebosto's Avatar
Chebosto
which 18x9.5+22 wheel did u get that was cracked?
Old Sep 23, 2009 | 02:40 PM
mistico's Avatar
mistico
FN01R-C.
I really liked the wheels but I must have run over a pot hole or maybe an off-track excursion did it.
Old Sep 23, 2009 | 03:50 PM
Chebosto's Avatar
Chebosto
i dont want to hijack this thread into a FS..
but i got two for sale if u want em. i dont use em any more.. they were my drifting wheels.. they're like pristine condition too..
18x9.5 +22
pm me..
Old Sep 23, 2009 | 04:43 PM
Done Deal DR's Avatar
Done Deal DR
Talk about coming through...
Old Sep 23, 2009 | 09:03 PM
mistico's Avatar
mistico
Right as I have new wheels on the way. Crap.
Good thing the new ones are a few pounds lighter. At least that makes me feel better bahaha
PMed you.
Obadabot
Jun 18, 2023 11:31 PM
