315 25 20
Old Jan 10, 2010 | 04:34 PM
Bigchef66's Avatar
Bigchef66
Default 315 25 20
Is anyone running or tried to run 315 25 20 tires on the rear of their 350.
Rolling radius is perfect but would like to know about any clearance issues (12" wide rims 38mm offset)
thanks
Old Jan 10, 2010 | 04:55 PM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Old Jan 10, 2010 | 08:34 PM
What happened to the 18x10 wheels?
https://my350z.com/forum/wheels-and-...8x10-22-a.html
And the 20x10 wheels?
https://my350z.com/forum/wheels-and-...4-corners.html
Old Jan 11, 2010 | 01:03 PM
Bigchef66's Avatar
Bigchef66
Originally Posted by davidv
18's were replaced by the 20's as they didn't suit the do luck body and the 20x10's were destroyed when my mechanic crashed my car just before Christmas. 20x12 now purchased for the rebuild. Sorry for not stating all that in my first post
Old Jan 11, 2010 | 01:18 PM
Done Deal DR's Avatar
Done Deal DR
I currently run 295/25/20's in the rear, I believe I could easily fit 315/25/20's on my 20x11's. I have iForged though, and they don't release their offsets so I can't help you out there. I've been able to roughly measure them out to be mid high 20's. My fenders are rolled, with stock body otherwise.
If you're using +38 offset on a 12" wide rim, I'd be more concerned about inner clearance.
Old Jan 11, 2010 | 01:21 PM
Done Deal DR
Obviously I'm saying be more concerned with inner clearance, assuming with the Do Luck install you're cutting the fenders to properly install the widebody so it actually makes a difference.
Old Jan 12, 2010 | 07:29 PM
Just seeing if you are a baller or a faker. Baller status for you. Install 315 mm tires. Run some serious camber.
kostat26
Sep 8, 2007 10:38 AM
sentry65
Mar 29, 2005 09:34 AM
RedShft
Feb 10, 2004 10:31 PM
