Is there a way to manually reset TPMS?
Old Jan 20, 2010 | 08:22 AM
dfresh713's Avatar
dfresh713
Master
Default Is there a way to manually reset TPMS?
I did a search and some people claimed that they could, however there is no how to DIY. I upgraded to Track Rays off an '08, however the TPMS lights flash as if the TPMS are not registering. How do you DIY reset the TPMS?
Old Jan 20, 2010 | 09:19 AM
Thermal1's Avatar
Thermal1
If you are using a different set of TPMS out of the new wheels, you need to go to a nissan dealership to get them synced up.
Or, swap your old TPMS sensors into your new wheels (This might be the cheaper option).
Old Jan 21, 2010 | 08:08 PM
PDX_Racer's Avatar
PDX_Racer
Or buy the $2500 TPMS re-programming tool...
Old Jan 21, 2010 | 08:26 PM
Spike100's Avatar
Spike100
^^ And then purchase the software to operate the Console, and pay for the updates and software support...
It's no wonder the dealership must charge what some people think is a high fee to reset the TPMS sensors. It isn't only the 5 minutes of labor that the dealer needs to recapture its cost to provide this service.
--Spike
Old Jan 22, 2010 | 03:09 AM
DavesZ#3's Avatar
DavesZ#3
There is a thread over on G35Driver where somebody claims to be able to reset it "manually". I've never seen anybody here report that they've tried it and it worked. In theory it should if it worked on a G35.
http://g35driver.com/forums/wheels-t...ial-tools.html
Old Jan 22, 2010 | 10:01 PM
zerostyle's Avatar
zerostyle
you guys are thinking too hard...discount tire has sensor reset tools...and we'll do it for free...just roll up and tell them you need to reset the sensors and its as easy as that
Old Jan 23, 2010 | 05:41 AM
DavesZ#3's Avatar
DavesZ#3
You're not thinking hard enough. That's the easy piece of the puzzle. That doesn't get the computer to recognize new or different sensors which is what the OP is needing done.
Old Jan 26, 2010 | 02:50 PM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
We have reset tools so you can do it at home as well.
Old Jan 26, 2010 | 03:17 PM
DavesZ#3's Avatar
DavesZ#3
Reset or Reprogram?
Old Jan 26, 2010 | 03:34 PM
neal@tirerack
Reset tool. Has a OBDII connection. Runs $135 + shipping.
Old Jan 26, 2010 | 03:38 PM
crg914's Avatar
crg914
Has anyone with a Z verified that this works? Sounds like a good option.
Old Jan 26, 2010 | 05:01 PM
Spike100's Avatar
Spike100
Originally Posted by DavesZ#3
Reset or Reprogram?
Dave, … What is the difference between “Reprogram” and “Reset?”
I’m confused by this terminology. The Z’s ECU only supports 4 sensors.
For example, I have two dedicated wheel/tire setups (winter and summer). I swap the setups (the tires mounted on the wheels).
If I mount sensors in each set (so I have 8 sensors in all, 4 for in each setup), would I be “reprogramming” or “resetting” when I mount/swap the wheel/tire setups that already contain dedicated sensors?
Sorry if this is a dumb question, but I’m confused.
--Spike
Old Jan 26, 2010 | 05:03 PM
stradaONE8's Avatar
stradaONE8
+1, I have the same issue now. 2 sets of wheels, one original TPMS, one new set, what is the best way to use both without running up a 100 dollar tab every winter and spring?
Old Jan 26, 2010 | 05:21 PM
DavesZ#3's Avatar
DavesZ#3
--Spike
I suspect different people have different definitions, but my understanding of this over the last couple of years is like this. There is an activation tool that you touch to the valve stem of the TPMS sensor. Basically, it wakes up the sensor because it is normally "off" until the car is driven about 20 mph. Those tools are widely available and from what I've heard, they can "reset" or "reboot" or "re-initialize" the sensor. Note that there is no connection to the car or ECU with that device so nothing is being changed on that side of the system.
At the dealer, in conjunction with the activation tool, the tech will use the Consult system to "reprogram" the computer side. Remember that the computer only recognizes 4 sensors at a time. Each sensor transmits a unique ID that the computer looks for. The activation tool does not change the ID, it only make the sensor transmit its ID. Consult has to be used to tell the computer to recognize a new or different ID.
By my definition, "reset" only affect the sensors; reprogram affects the ECU/computer.
ATEQ that Neal shows above claims to have a tool that reprograms the ECU much like Consult would do. Not sure if that's the one Neal says is $135 since I can't find it on their site.
Old Jan 26, 2010 | 10:25 PM
raycs7's Avatar
raycs7
The Ateq Neal mentions can read the ID's of the sensors that came preinstalled when connected to the OBD11 connector.
You can store those.
If the sensors are preinstalled on new wheels you will need the sensors ID to register to the car.
Also, I think you can only select one type car.
Out the box it sees Infiniti but I needed online update to see Nissan.
I will try this soon but I am looking for a way to read my Infiniti G coupe, as well as the 03, 06 and 07 350Z's I own.
I wonder if I can run the program off different flash [or SD] drives for each model car..
Old Jun 22, 2010 | 01:29 PM
dfresh713's Avatar
dfresh713
Master
I'm going to try the discount tire today.
Old Jun 22, 2010 | 03:20 PM
terrasmak's Avatar
The link to a review on a 350Z https://my350z.com/forum/wheels-and-...-own-tpms.html
Old Jun 22, 2010 | 03:33 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
is there a special tool needed to mount tpms to a rim???
Old Jun 22, 2010 | 04:02 PM
shingr's Avatar
shingr
12mm deep socket or wrench, assuming new seals..
Old Mar 23, 2011 | 09:09 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Bump..
So there's no way to reset the TPMS on our own? The G35driver thread doesn't really have anything you can actually attempt on your own as all the procedures are missing vital bits of info and I'm too cheap to buy the ATEQ tool.
Darkspy
Sep 7, 2015 09:09 PM
