Look at what happened to my tire
Old Feb 1, 2010 | 06:23 PM
skynetz's Avatar
skynetz
Default Look at what happened to my tire
Pictures taken with my Nexus One
Attached Thumbnails Look at what happened to my tire-2010-02-01-14.27.26.jpg   Look at what happened to my tire-2010-02-01-14.30.02.jpg
Old Feb 1, 2010 | 06:32 PM
VO...'s Avatar
VO...
Administrator
Moved...
Old Feb 1, 2010 | 06:34 PM
Chromex319's Avatar
Chromex319
So?
Old Feb 1, 2010 | 06:37 PM
huyrua's Avatar
huyrua
You hit a curb? Air tumor
Old Feb 1, 2010 | 07:20 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Looks like you have dick for tread left anyway, with some pretty bad inside toe/camber wear....wut's the problem?
Old Feb 1, 2010 | 07:23 PM
Please do not provide an explanation. One thing we like around here is guessing games.
Old Feb 1, 2010 | 07:53 PM
S30Love's Avatar
S30Love
he drifted over pothole.
Old Feb 1, 2010 | 08:44 PM
skynetz's Avatar
skynetz
I have no idea what happened. My friend was driving behind me and noticed the tumor on my tire.
Old Feb 1, 2010 | 08:46 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
That's a weak spot in the rubber. My sister had one of those in a bicycle tire one time and it was a monster explosion when the thing let go. DO NOT DRIVE ON IT!!!!
If you don't have a gazillion miles on it, then check on warranty, if there was one. Judging by the looks of it, that's a manufacturing problem.
Old Feb 1, 2010 | 08:58 PM
Nexx's Avatar
Nexx
another weird occurance with a falken tire.
Old Feb 1, 2010 | 10:24 PM
dranom's Avatar
dranom
coz its falken
Old Feb 1, 2010 | 10:42 PM
SatchScream's Avatar
SatchScream
Did you happen to hit a parking block in the middle of the night while driving through an empty parking lot so you could go check on a couple of co-workers that hadn't left the parking lot yet?
Old Feb 1, 2010 | 10:45 PM
skynetz's Avatar
skynetz
Was that you on the other side????
Old Feb 2, 2010 | 07:59 AM
ssawa's Avatar
ssawa
Is this common with Falkens? I have Falken 452's with my rear tire the same size as Skynetz but no problems with mine.
Old Feb 2, 2010 | 09:28 AM
PikesPeakZ's Avatar
PikesPeakZ
I have had that happen to my wife's Nitto's and the tire shop says it's from hitting a pothole. They will generally measure the tread depth and prorate the new tire based on tread life of the tire but because our cars have camber the inside always wears first and leaves no tread depth. Just what I was told not sure if it is a legit circumstance but sounds reasonable.
Old Feb 2, 2010 | 01:14 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
All cars have camber. If it is aligned and adjusted properly for a street alignment it should wear evenly across the tread.
Old Feb 2, 2010 | 01:46 PM
ATX350's Avatar
ATX350
Same thing happened to my nitto's:
https://my350z.com/forum/wheels-and-...onths-old.html
Don't drive on low tire pressure. Lesson learned.
Old Feb 2, 2010 | 02:14 PM
fairladyboss's Avatar
fairladyboss
the same thing happened to my brothers falken tires
Old Feb 2, 2010 | 02:55 PM
Waiz's Avatar
Waiz
Tire boner
Old Feb 2, 2010 | 03:25 PM
neal@tirerack's Avatar
neal@tirerack
Classic impact damage. Belts have shifted due to blunt force trauma causing the sidewall to bulge.
