spacer and tires.
I came up with some questions about spacer and tires. i saw some thread of drifting wheels and a lot of ppls mentioned that most of drifters put wheel spacers when drifting.. what do spacers actually do to make them drift better? Will i have to roll up the fender if i go with 25/30mm combo for 07 350z?
i also heard that wide rear tires aren't good for drifting... i never get why.. plz explain it to me
PPl say that OEM rims have the worst(?) offset. what's the best offset for drifting, then??
sorry for your inconvenience..
thx
thx
lol... wow you need help. spacers do not do much in terms of performance. it's 99% because cars look more aggressive with the wheels sticker out closer to the fender. you'll have to roll your fenders depending on how low you slam your car. do some research before you post silly threads like this. the only reason "wide tires" wouldn't be good for drifting is because drifting requires getting the back end loose and if there's too much traction, you won't be able to do it as easily. it's common sense...
I am an avid drifter...........
the only reason i use spacers when drifting is because I own 18 wheels for my car!
as a budget drifter, i tend to buy wheels at deals when i can! doing so means i have also acquired spacers on CList, forums, etc and I now currently own a set of 15mm, 20mm and 25mm spacers!
Yup, i have 3 sets of spacers....but then again, i own 18 wheels....so they come in handy.
You dont need spacers if your adding tie rods...that doesn't matter...
-J
-J
-J
-J
so it sounds like spacers are used for turning random offset wheels to fit for drifting huh? then whats the good offset for drifting?
https://my350z.com/forum/drift-308/
There is a whole sub-forum just for motorsports.
All the info you need can be found there.
Enjoy
Enjoy
No, to fit for that "drifting look". You don't need spacers unless the wheels are the wrong offset and hit the suspension or calipers OR if they are sunken in (but fit) and you want them to be "pushed out" more.
I use them only cuase i bought 6 wheels off a buddy for 200 bucks! I didnt let sad offset keep me from picking up decent spare drifting wheels.....
thats all.......its not "needed" or does not help "performance" when drifting any much more than making it all look right, getting the stance right is about it.....
-J
no one's telling me the number of "good" offesets. Is the offset fine as long as the rim clears the caliper? that's it? if so, then i don't get why OEM rims have bad offset..they clear calipers..maybe not BBks.
FromGtoZ
Sep 20, 2015 03:41 PM
