How Big Can You Go?!?
Old Mar 2, 2010 | 09:38 AM
jeglazer's Avatar
jeglazer
Default How Big Can You Go?!?
I have a 2003 Track Pack, with factory Ray's wheels. If i want to increase my tire size, how big can I go on the factory wheels? I've installed the Hotchkis TVS (1" drop), and I want to run 15MM spacers on all four corners. Does this leave any room for a bigger tire? Thanks again for all your input guys!!
Old Mar 2, 2010 | 11:03 AM
scotts300's Avatar
scotts300
265 in the rear and 255 max up front on those wheels.
245/40/18 front and 245/45/18 rear is a nice combination. Since your car is lowered, you could also run 255/35/18 front and 255/40 or 265/35/18 rear.
Old Mar 2, 2010 | 11:13 AM
Z Infidel's Avatar
Z Infidel
The Track model is staggered.
Old Mar 2, 2010 | 11:58 AM
terrasmak's Avatar
and your point is? The sizes you highlighted in red are staggered too, just in height. That setup works great for handling.
Old Mar 2, 2010 | 12:02 PM
dkmesa350z's Avatar
dkmesa350z
Like others mentioned, you are limited by the width of the wheel. I believe most tire manufacturers recommend no larger than 245 on an 8" wheel and 255 on an 8.5" in wheel. You would probably be okay if you stretched that by one size, but I wouldn't recommend going to much wider.
Old Mar 2, 2010 | 12:05 PM
BonesZ33's Avatar
BonesZ33
+2...I've seen 265 fit on the 8.5 rear track rim, but its not factory recommended.
Old Mar 2, 2010 | 12:32 PM
scotts300's Avatar
scotts300
All Z models are staggered from the factory from 03 through current.
Agreed. 245 is ideal on an 8 and 255 is ideal on an 8.5, but 10mm over is acceptable, but no larger for most applications.
Old Mar 2, 2010 | 01:45 PM
gerryg2153's Avatar
gerryg2153
I have 265/35/18 NT05 all around on 8.0/8.5 (stock 08) with 15mm/20mm spacers and lowered - no rubbing issues what so ever. . .
It was larger that recommended for the 8.0 rims - and was a little bit of work for them to get them seated correctly - but the seem to be fine. . . . the rears were easy-
May 30, 2017 03:28 PM
Jambo016
Sep 16, 2016 01:08 PM
