Lug Nuts Wont Stay Tight and Fall Off
Old Mar 23, 2010 | 06:42 PM
  #41
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by DavesZ#3
[SIZE="3"]
BTW - here's what happens when you use the wrong thread pitch...
that is sweet I would kill myself if that ever happened
Old Mar 23, 2010 | 06:43 PM
  #42
ZS14RR's Avatar
ZS14RR
fugged up. glad youre still alive
Old Mar 23, 2010 | 07:27 PM
  #43
Barnabas's Avatar
Barnabas
National Z Club President
guess when he double checked pitch size he didnt look at the right one
Old Mar 23, 2010 | 07:50 PM
  #44
jasabeast's Avatar
jasabeast
or he doesnt know the specs of his car
Old Mar 23, 2010 | 08:47 PM
  #45
Wu-Watt's Avatar
Wu-Watt
AHAHAHA I've seen that RX-7 vid 1000 times!
The topic isn't really funny cuz this guy could have killed ppl with his ignorance.
And if I was out at track day and that happened to me I would shoot myself square in the brain.
Old Mar 23, 2010 | 09:51 PM
  #46
tware's Avatar
tware
came for the RX 7 video and to suggest wrong pitch, leaving satisfied.
Old Mar 23, 2010 | 10:02 PM
  #47
R350Zz33's Avatar
R350Zz33
part # u really need
711-455
Old Mar 24, 2010 | 04:47 AM
  #48
cheshirecat79's Avatar
cheshirecat79
The $64,000 question is: What pitch are the threads? 1.25 or 1.5? The stud on the Z are 1.25. It's possible to make the mistake and put on 1.5 pitch which won't screw on or torque down properly.
I agree- usually the thing that causes this is an incorrect spline. I know you said that you verified that it was correct, but even if it is correct, you're basically now looking at picking up some new lugs.
Either get some Loctite or some different lugs, imo... preferably the latter.
Old Mar 24, 2010 | 04:57 AM
  #49
synth19's Avatar
synth19
I just picked up some nice lugs from Touge Factory in Elk Grove, they have a nice collection- Rays, Project Kics, etc. Considering you went with Montegi wheels, I would recommend a reasonably priced set from Mcgards. Arguably the safest AND strongest lugs on the market. You can probably find a set for around $75 or so (with locks).
Old Mar 24, 2010 | 06:42 AM
  #50
xzotklr's Avatar
xzotklr
Originally Posted by gidiup
Here are the lug nuts I'm using right now. These are Dorman Wheel Lug nuts. Or I should say trying to use.
My buddy had those same lugs and they would come off. get better lug nuts.
Old Mar 24, 2010 | 12:42 PM
  #51
tware's Avatar
tware
However, now that you've been trying your damnedest to tighten 1.5 pitch lugs, I'm not sure I'd trust the studs now when you do get the proper pitch lugs back on. Not that I've done it personally, but I've seen where 1.25 lugs would no longer tighten either after 1.5 had been tried. I'm not sure if the threads would be something I'd trust even if they do seem to tighten now.
Old Mar 24, 2010 | 01:44 PM
  #52
synth19's Avatar
synth19
They are 1.25. I thought the same thing. Triple checked it.
Are you sure you gave us the right part number? As DavesZ#3 pointed out, the part number you mentioned is not 12x1.25, it's 12x1.5.
Old Mar 24, 2010 | 03:38 PM
  #53
dhays's Avatar
dhays
I've seen it a lot as well, it crops up every few months on the RX7 forums. I've seen it attributed to everything to wrong lugnuts, to under torquing the nuts, to over torquing the nuts.
It is just painful to watch though.
Old Mar 24, 2010 | 08:02 PM
  #54
Waiz's Avatar
Waiz
That vid is bananas.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
