Square Wheel & Tire Setup Questions
Old Mar 29, 2010 | 10:07 PM
Villain's Avatar
Villain
Default Square Wheel & Tire Setup Questions
I'm going to be getting a killer deal on some volks that are 19x10.5 +22 all around and wrapped in 285/30/19. Are there any handling issues I might need to be aware of by running a wheel that wide up front? Overall what are your thoughts about a square setup? A huge advantage is that I can rotate the tires!! hahaha I'm going to be ordering coilovers, camber kit and camber arms this week as well to make any adjustments needed to support the wheels as well. Any input is appreciated, these wheels are super rare and I've only seen one other Z sport these for a short time which is why I wanna get these
Old Mar 29, 2010 | 11:22 PM
hellsoldiers08's Avatar
hellsoldiers08
hmm my brother has 19x10.5 in the back and the rims/w tires looks huge! i mean Huge!! going off from what i see from the back of the car i would say no... but i mostly likely wrong.
Old Mar 30, 2010 | 03:58 AM
duro78's Avatar
duro78
start rolling those rear fenders from now not sure about the fronts fitting but it will look nice i actually prefer the square setup
Old Mar 30, 2010 | 06:52 AM
CORNELL's Avatar
CORNELL
probably gonna have to run a good amount of camber in the front to fit the tire, but the back will be fine. it all depends how low you go
Old Mar 30, 2010 | 07:52 AM
Villain's Avatar
Villain
thanks guys
anymore input out there?
Old Mar 30, 2010 | 07:55 AM
SuperBlack350z's Avatar
SuperBlack350z
there is no way you will be running 285 in the front with a 10.5 +22 wheel.
Old Mar 30, 2010 | 08:23 AM
CORNELL's Avatar
CORNELL
ive seen 295/30/19 all around with hoosiers which run wider than most tires. great autox setup with the right camber
Old Mar 30, 2010 | 10:31 AM
Villain's Avatar
Villain
What if I run a different size tire?
Old Mar 30, 2010 | 10:37 AM
Toby-22's Avatar
Toby-22
im running 10.5 +22 all around. You can go with 255/35 up front and not rub after lowering it. 285/35 will not work when dropped, too much rubber. At stock height you can pretty much run whatever size tires you want up front.
right now im at 10.5 +12 with 235/35 and i pull/rub the **** out of my fenders when i turn. Then again im tucking rims up front lol.Lemme ***** up some pics to help you
Old Mar 30, 2010 | 01:37 PM
crsracing19's Avatar
crsracing19
what are the advantages and disadvantaged to running a square setup vs staggered.
is just more under steer or is a square setup more for a track or really just driving preference
Old Mar 30, 2010 | 02:59 PM
Done Deal DR's Avatar
Done Deal DR
All else equal, more OVER steer.
Old Mar 30, 2010 | 03:00 PM
Done Deal DR
On the street, I'd say it's more for preference...
Old Mar 30, 2010 | 03:01 PM
Villain's Avatar
Villain
man you're one of the people with a slammed ride i was hoping would answer! thanks for the input bro, looks like i'm gonna go ahead and pick up these wheels. what is your current suspension set up?
Old Mar 30, 2010 | 08:59 PM
Handling and common sense went out the door a long time ago. Like drifting, this is a style forum.
Old Mar 30, 2010 | 10:52 PM
crsracing19
so which one offers better handling characteristics then
Old Mar 30, 2010 | 11:34 PM
350Zdj's Avatar
350Zdj
@OP...
Many people run square set up for circuit driving because it makes the car more neutral with slight oversteer.
If it the offset was +30 you can mount a pair of 285's upfront.
+22's with 285's might cause some rubbing. You can either switch to 265 or get your negative camber set to -2.5 or something but this will give you a MASSIVE oversteer.
best option is to get 255 or 265's with some negative camber. Keep that pair of 285's as spares for your rear wheels.
a friend of mine has got an offset of +20 with 255's (stock camber setting) and the rubber is almost sticking out of the fender.
Old Mar 31, 2010 | 12:37 AM
crsracing19
i was going to order a pair of ekei nto3+m tomorrow 10.5 rear 9.5 front 18inch
what offset should i get so i wont have an issue with rubbing and what tire sizes should i get for both any help much appreciated
Old Mar 31, 2010 | 01:16 AM
350Zdj's Avatar
350Zdj
depends on the rubber dimensions u are planning to mount.
search the wheel threads and check out some hot setups. It will give you a bunch of ideas.
Old Mar 31, 2010 | 02:10 AM
duro78's Avatar
duro78
JPE22 lookin real sexy, Op its all personal preference like the guys are saying now square is better for the track but imo I like the way it feels on the street the car feels more nimble and steering input is faster, it makes an otherwise heavy car feel lighter.
Old Mar 31, 2010 | 05:09 AM
G353535's Avatar
G353535
For square
More Nuetral Handling
Can rotate
For staggered
More understeer
looks better(Rear sits more flushly)
can not rotate
For NT03
i run 275(9.5 with +27) front and 295(10.5 with +30) Nitto Invo
No rubbing without fender rolling
