Need some input for running 18x9.5 all around
Old Apr 22, 2010 | 09:44 AM
powchikapow's Avatar
powchikapow
Default Need some input for running 18x9.5 all around
I got an 03 based Z, thinking of running SSR Type F 18x9.5 ET22 all around. it is for everyday commute. Also planing for weekend track events. Wondering if those size and offset would work. Input on tire size will be appreciated as well.
Old Apr 22, 2010 | 10:15 AM
diablox1's Avatar
diablox1
that setup fits. some guys on here will probably advise you to go more aggressive (as i would). with 18x9.5 you'd be good with a 275 series tire
Old Apr 22, 2010 | 10:34 AM
scotts300's Avatar
scotts300
Looks good. 275s all around and you can rotate them. If you don't plan on rotating, you could go larger in the rear.
Old Apr 22, 2010 | 11:10 AM
Entaille's Avatar
Entaille
I would go 275 all the way around. I have 18x9.5 +20 all the way around with 245/40 fronts and 275/40 rears and I do not like it much. going 275 all the way around when the fronts wear enough.
Old Apr 22, 2010 | 11:22 AM
theianmcdougall's Avatar
theianmcdougall
i have 9.5 all around on 225's, hehe
cant fit much bigger with F -4 and R -9
but thats just my drift setup untill the rest of my big boy rims come in
Old Apr 22, 2010 | 11:34 AM
plumpzz's Avatar
plumpzz
If i was to do it again, i'd do 18X9.5 + 12 all around. Much cleaner look than the staggered look.
Old Apr 22, 2010 | 12:04 PM
Dragonbreath's Avatar
Dragonbreath
What's the widest tire you would run on that setup front and rear? Could you run 265 all around lowered on stance coils?
Old Apr 22, 2010 | 02:55 PM
duro78's Avatar
duro78
Im running that (265 all around) setup now plus with 25mm spacer in the back and will be adding 10mm up front. I actually prefer this setup the car turns quicker plus feels lighter.
Old Apr 22, 2010 | 04:03 PM
uglyduc's Avatar
uglyduc
running 18x9.5 +15 all around no spacers on 275/35
Old Apr 22, 2010 | 04:22 PM
Dragonbreath
You get alot of rubbage?
Old Apr 22, 2010 | 05:37 PM
uglyduc's Avatar
uglyduc
No rubbage, but I run atleast -3.0 up front and -2.5 in the rear which may be a little aggressive for most DD, but I love it..
Tires are Dunlop Durezza Star Specs
My cars the black HR, second to last picture under the dyno day event.
Zcar Dyno Day
Old Apr 22, 2010 | 10:37 PM
Dragonbreath
Do you have any pics?
Zcar Dyno Day
You got anymore pics?
Old Apr 22, 2010 | 11:14 PM
CircleHeartX's Avatar
CircleHeartX
do it .. i got it
Old Apr 23, 2010 | 02:23 AM
duro78's Avatar
duro78
Not the best pics but here you go. I had to roll the rears which was easy just used a heat gun and a pry bar.
Attached Thumbnails Need some input for running 18x9.5 all around-0331001126.jpg   Need some input for running 18x9.5 all around-0331001126b-1.jpg   Need some input for running 18x9.5 all around-0331001127-1.jpg
Old Apr 23, 2010 | 03:10 AM
Mastoras's Avatar
Mastoras
With 9.5 vs 8.0 in front (OEM specs), how it will affect handling and performance? Isnt it too wide ?
Old Apr 23, 2010 | 04:08 AM
duro78's Avatar
duro78
^ no it wont it actually increases it
Old Apr 23, 2010 | 04:58 AM
plumpzz's Avatar
plumpzz
If you run a 275/35 tire it shouldnt rub, dropped 1''. You may have to cut the fender in the rear, but I doubt it. 275/40 will likely rub on soft springs.
apex locator
Jul 23, 2021 02:27 AM
