RPF1 17x9.5 +18 w/ 275/40's All Around?
Old Apr 26, 2010 | 08:41 AM
bnag0's Avatar
bnag0
Default RPF1 17x9.5 +18 w/ 275/40's All Around?
I have done quite a bit of research on the RPF1's and only have a few questions left thanks to many people on this site, i really appriciate all the effort those people have taken to educate me!
My main concern about the RPF1 in this offset/width is rubbing issues.
- I have seen people with no problems running these wheels but their car is not yet lowered
- For the people who run these with a drop "for track" usually have a -3.00 camber, this kind of camber used on the street is just rediculous for tire life even when rotating, this is my guess... no one has told me how long a tire would last while running this set up.
Question: Where is the point of rubbing? How far can i drop before rolling the fenders and adjusting my camber?
I guess i could also go with a 17x9 +22, but the only problem there is the clearance for the Brembos or any other bbk i might install in the future..
So i could run a spacer...
Opinions would be great on this, Thanks everyone for even getting me this far...
Old Apr 26, 2010 | 10:07 AM
sfarrah's Avatar
sfarrah
I would think you'd be ok with that width and offset and a small amt of camber. Worst case scenario you might need a mild fender roll. Any rubbing that would occur would be the top lip of the fender. I don't have any issues with rubbing with 275/40 race rubber on the 17x10's but my fenders were rolled years ago.
17x9 is an option, but always run the widest wheel possible.
Old Apr 26, 2010 | 12:14 PM
bnag0's Avatar
bnag0
For a full out track car i agree...
The car comes stock with 18x8.0 +30 Front and 18x8.5 +33 Rear (2007)
I really plan on running a totally square setup but i am mostly going to be on the street with this car not the track, if i were to run anything bigger than 9.5 in the front i would have to run with some serious negative camber which is a no go. I rather run close to 0 degree camber and when i am going to the track i can always put myself into the negatives. But i need to know how low i can go...
Thank you so much for your feedback!
Question1: When you run your 17x10 how much lower is your car?
Question2: What wheels are they and what offset?
Question3: What is your camber with this set up?
Old Apr 26, 2010 | 02:22 PM
CORNELL's Avatar
CORNELL
my camber is at -2 with a 10" wheel in front and a 275 is almost at a rubbing point, but i havent seen any problem with the camber wear as long as toe is good.
Old Apr 26, 2010 | 03:04 PM
scotts300's Avatar
scotts300
The 17x10s that work are the 5Zigen FN01R-C in the +25 offset. They clear with 275s without needing any crazy camber.
The problem, in my opinion, is assuring that the RPF1 wheels will clear a larger than non-Brembo brake kit. The 17" RPF1s have a funky design in the barrel right behind the spokes of the wheel - a spacer will not always solve that problem if the intent is to have a 275 tire. If you move to the 18" RPF1, all those problems go away, as it does with most other 17" wheels (SSR Comps, MB Weapons, 5Zigens, etc., etc.)
My last pair of wheels were 17x9.5 +31 (or 34?) SSR Comps with 275s all around. I never tried, but I wouldn't think they would have worked in the front had the fronts been "out" an additional 1/2" (13-16mm delta with your and my offsets). When you lower it, that'll add some static camber naturally, it'd be a shame to dial that part out of it, in my opinion. Just confirm the toe is in spec.
Old Apr 26, 2010 | 04:43 PM
bnag0's Avatar
bnag0
If you have a -2.00 degree camber how would your toe adjustment give you more even tire ware?
Old Apr 26, 2010 | 04:57 PM
bnag0's Avatar
bnag0
How much further can you extend the wheel outward until you run into rubbing issues when your car is lowered? I mean a .50" isn't all that much people make it seem like the 350's wheels are 3 feet away from the fender.... Closer to the fender would be nice and all but im just trying to find a setup that works without giving me a head ache.
Not to be off topic but for example:
What about the 5zigen FN01R-C 17x9 +35 this will stick out 8mm more than the stock wheels, id say that's pretty safe... Although id rather run the +15 offset which would land me at 28mm more.
p.s. i extremely hate looking for THE wheel.
Old Apr 26, 2010 | 05:01 PM
bnag0's Avatar
bnag0
This offset would stick out an extra 30mm though...
Am i missing something? lol
Old Apr 26, 2010 | 08:44 PM
CORNELL's Avatar
CORNELL
toe is the biggest factor in tire wear not camber. i can take pics of my tires if you would like, 6 months of about a 45 minute daily commute and no sign of inner wear.
Old Apr 26, 2010 | 09:01 PM
CORNELL's Avatar
CORNELL
most people that run 17's with a 275/40 all around move on to 18's with 285's and they still fit, including scotts300
example of 18x9.5+12 285/30/18 hoosiers all a round...
Old Apr 26, 2010 | 09:11 PM
terrasmak's Avatar
Well right now i'v running 17x9 +17 up front with 275/40-17, -1.8 camber and had around a 1 inch drop, no rubbing
Old Apr 26, 2010 | 10:09 PM
scotts300's Avatar
scotts300
Compared to a 17x9.5 +18? Yes, you're missing something.
A 17x10 +25 "sticks out" (i.e. comparing the outer most face/lip of the wheel) ~6mm more than the the 17x9.5 +18. When I ran BIG 275s, it was very close to rubbing on the inside.
This is true! And I'm on my way to running 295/30/18s next!
Old Apr 27, 2010 | 05:43 AM
bnag0's Avatar
bnag0
So if i went with the 17x9.5 +18 i would be 6mm safer than the 18x10+25
And ive seen these wheels clear the stock brembos.
Why not go with these?
(Im really shooting for a 17" because of price and weight)
Old Apr 27, 2010 | 06:46 AM
scotts300's Avatar
scotts300
Yes, but that doesn't mean the barrel of the wheel on the RPF1s will fit w/o a spacer. I think the lower offset wheels are ok, but I'm being cautious because the math didn't workout as expected on a few sets I've seen.
I understand your logic of price and weight on the 17s vs 18s, and although that's mostly true, there certainly are lightweight 18" wheels out there and take-off tires that are cheaper than new 17s. I had the same logic, and am happy with my change to 18s (18x10s all around for track, 18x9s for autox).
Old Apr 27, 2010 | 08:49 AM
aRYip's Avatar
aRYip
hey scotts300, thats Work CR KAI right?
Did you roll fender in order to fit +12 offset wheel?
Old Apr 27, 2010 | 10:10 AM
bnag0's Avatar
bnag0
Ugh maybe ill just go with the 5zigen FN01R-C 17x9 +15, This only sticks out 28mm more in the front and 24mm more in the rear (compared to stock)
compared to a RPF1 17x9.5+18 which is 31mm more in the front and 28mm rear.
Plus the 17" FN01R-C's are cheaper and im almost possitive ive seen them clear bbk's, only downfall would be they are like 1-2 lbs heavier than the RPF1's.
What you think Scott? You are the only one giving me some answers through out all my wheel threads ive ever made lol.
Old Apr 27, 2010 | 10:40 AM
scotts300's Avatar
scotts300
It's too bad you weren't looking a few weeks ago, I let both my 17" sets go. I had a set of 17x10 FN01R-Cs, and I still see some of those out there, but I had a sweet set of SSR Competitions in 17x9.5 that were under 16# a piece. They were fantastic wheels. It looks like the 17x9 5Zigens are ~2# heavier than the 17x9.5 RPF1s, but like you said, you should be able to get them for a bit cheaper. The 17" FNs do clear Brembos and the 332mm StopTech BBk.
Honestly, they 17x9.5 +18 RPF1s may work. I am just being cautious because I've seen the higher offset ones not work due to the funky barrel design.
Here are the 17x10 +25 FNs: https://my350z.com/forum/norcal-mark...ed-wheels.html
Old Apr 27, 2010 | 11:13 AM
JasonZ-YA's Avatar
JasonZ-YA
I run MB WEAPON 17X9 WHEELS.
Usually I run:
FRONT:
17x9 +27 with 275/40/17 R comps
REAR:
17x9 +17 with 275/40/17 R comps
May also see the MB Competitions...
-J
Attached Thumbnails RPF1 17x9.5 +18 w/ 275/40's All Around?-img_4500.jpg
Z1 Performance
Jun 19, 2011 11:04 PM
pgraham86
May 31, 2009 10:28 AM
vispre
Jul 23, 2008 10:22 PM
Spoiled Z
Apr 12, 2008 01:50 PM
