wheel n spacer question
Old Aug 25, 2010 | 12:10 AM
ma6icman's Avatar
ma6icman
Default wheel n spacer question
I googled n couldn't find it, I have 18x10 wheels with a +25 offset and I'm lowered on sportlines, I'm getting a good deal with 30mm spacers with studs, would there be a issue running these spacers?
Old Aug 25, 2010 | 12:13 AM
What kind of issue?
Old Aug 25, 2010 | 12:15 AM
terrasmak's Avatar
depends on the tires you want to run and how rolled your fenders are.
Old Aug 25, 2010 | 12:19 AM
ma6icman's Avatar
ma6icman
well my fenders aren't rolled at all right now, is a 30mm spacer to big to run on a z?
Old Aug 25, 2010 | 12:26 AM
You can measure the distance between the top of the tire and fender. If you have 30 mm to spare go for it.
Old Aug 25, 2010 | 01:34 AM
terrasmak's Avatar
Should work great if your running a 245/45-18 and have rolled and pulled fenders.
Old Aug 25, 2010 | 01:53 AM
Zed_UP!'s Avatar
Zed_UP!
i have similar issue too.. i ordered 19x9 -10 front 19x10 -20 rear on my wheels, ill most likely be running 225 35 19 back 205 35 19 front...but im slammed with no fender rolling negative camber, i was thinking 20 mm spacer front 30 rear?
Old Aug 25, 2010 | 02:01 AM
BiggieB15's Avatar
BiggieB15
for your set up I would go with 215/35 or 225/35 for the front and 235/35 or 245/35 for the rear IMO....
Old Aug 25, 2010 | 02:10 AM
BiggieB15's Avatar
BiggieB15
It all depends what route you wanna go with this set up.....Do you want to go stretched tires or meety tires? How low your car is and all that stuff...In my opinion I would go with 25mm for the front and 30mm for the rear with 225/40 for the front and 255/35 for the rear but again that is just my opinion....I used to have 30mm spacer for the rear and 25mm for the front and never had a problem with the spacers....You'll get more help if you post a pic of your ride...
Old Aug 25, 2010 | 03:32 AM
JasonZ-YA's Avatar
JasonZ-YA
READ HERE:
https://my350z.com/forum/wheels-and-...er-thread.html
search is your friend..........if you don't find your answer there*post 15*, then ask/reply in that thread.
/thread...
-J
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
