Varrstoen Wheels Thread
Old Mar 26, 2012 | 01:22 PM
  #841
Rouse350z's Avatar
Rouse350z
Originally Posted by ZROCM
I have a set of 18x9.5 +22 Varrsteon wheels on order. My suspension is currently stock. I plan on running 275/40/18 in the rear and 255/40/18 in the front. I assume I'm OK running 255 in the front with no issues. Can anyone confirm this. Thanks in advance for any help.
I would hold that order and look at what ur ordering really quick because 18x9.5 +22 in the rear is not going to look that great. you would want some more poke so i would do 18x10.5 +22 in the rear and run 275/40/18 in the rear and have the 18x9.5 +22 up front with a 245/40/18 or 255/40/18. like for example im running 18x9.5 +12 front and 18x10.5 +0 in the rear with 225/40/18 front and 245/40/18 rear and it is very flush.
Old Mar 26, 2012 | 05:47 PM
  #842
ZROCM's Avatar
ZROCM
I see, so I should try to get more flush in the rear!
Old Mar 26, 2012 | 06:45 PM
  #843
Rouse350z's Avatar
Rouse350z
yes just run a 10.5 in the rear.
Old Mar 29, 2012 | 09:35 AM
  #844
KenE_Z's Avatar
KenE_Z
Finally got my setup installed.
F: 18x9.5
R: 18x10.5
Nothing crazy but much better than the stocks and drives/handles awesome!!
Ken
Attached Thumbnails Varrstoen Wheels Thread-z1.jpg   Varrstoen Wheels Thread-z3.jpg
Old Mar 29, 2012 | 09:39 AM
  #845
KenE_Z's Avatar
KenE_Z
I would look at the +12/+15 offset. I have posted a pic below in this thread of what this set up will look like.
Old Mar 31, 2012 | 08:18 PM
  #846
ZROCM's Avatar
ZROCM
Thanks! Are those wheels in the 'Mirror Silver' color?
Old Apr 2, 2012 | 07:42 AM
  #847
IanP's Avatar
IanP
19 x 9.5 ET2 (ET12 with 10mm spacers )
Finished in midnight purple
Old Apr 2, 2012 | 10:20 AM
  #848
NJVinny350z's Avatar
NJVinny350z
For those of you who went with matte black, what wheel cleaner do you guys use?
The one I bought leaves streaks behind, even after it's dry.
Old Apr 2, 2012 | 11:17 AM
  #849
1320king's Avatar
1320king
Default Gunmetal or black varrstoens
I picked up a set of 19 varrstoen 2.2.2s a couple moths ago, long storey short the guy had rattle canned them white (they look terrible) so its time for paint
What would look better on my ppw 06 z
Gunmetal or black ( flat semi or high gloss)
Your opinions are appreciated
Old Apr 2, 2012 | 11:36 AM
  #850
druboi's Avatar
druboi
Default Whats up peeps its been along time
What's good up in here
Old Apr 2, 2012 | 01:43 PM
  #851
Flo-ridaZ33's Avatar
Flo-ridaZ33
Use soap and water... no cleaner.
Old Apr 2, 2012 | 03:31 PM
  #852
TSG-Z's Avatar
TSG-Z
Luckily, you "practiced" on a cheap set of rims, now buy the TE's and start over! Seriously, rims are probably done! What rim cleaner did you use?
Old Apr 2, 2012 | 10:35 PM
  #853
NJVinny350z
I used some Meguiar's all wheel cleaner, and no they are not ruined, just took a little elbow grease to get the streaks out.
Old Apr 4, 2012 | 08:34 AM
  #854
ShineMaster's Avatar
ShineMaster
Thumbs up
Woah, what rim/tire setup is this??? Your PM box is full PikeZ!
[QUOTE=PikeZ_350;8641013]
Old Apr 4, 2012 | 08:46 AM
  #855
sofa king's Avatar
sofa king
you need some of this..http://www.detailedimage.com/P21S-M1...500-ml-Kit-S1/
Old Apr 5, 2012 | 01:20 PM
  #856
Hot Cu's Avatar
Hot Cu
SlammednFlush
Question Polished or Hyper Black?
Originally Posted by no vtec 4me
Car has been raised since these shots, BUTTTTT
19x10.5 with 235/245s et12 front et-3 rear
rolled fenders and some camber
Are these polished or hyperblack?
Old Apr 5, 2012 | 10:19 PM
  #857
NJVinny350z
Finally got some pics to show.
Old Apr 5, 2012 | 10:51 PM
  #858
1991ls13's Avatar
1991ls13
specs?
I`m on +12`s and gonna lower it and everything in about a week when i get them in, Probably going to get a very small spacer since i`ll be doing a roll and pull
Old Apr 5, 2012 | 10:53 PM
  #859
NJVinny350z
19x9.5+12, 19x10.5+12
Front: 235/35/19
Rear: 255/35/19
Lowered on BC Coilovers with a fender roll running -1.5 rear camber with SPC rear camber arms.
Old Apr 7, 2012 | 09:01 AM
  #860
ZROCM's Avatar
ZROCM
Default Varrstoen 18" weight
Does anyone know the weight of the Varrstoen Es2.2.1 18X9.5 wheels?
