Varrstoen Wheels Thread
Old Nov 20, 2013 | 11:34 AM
  #1641
Bmurray350z's Avatar
Bmurray350z
+12 clears brembos Waizzz. You'll be fine.
How did you ruin your wheel?
Old Nov 20, 2013 | 12:08 PM
  #1642
skoke70's Avatar
skoke70
Originally Posted by travlee9374
the fronts would poke out... do they have something between the two?
No they do not, +12 is all they have. Hopefully I can get the rim repaired?
Old Nov 20, 2013 | 02:55 PM
  #1643
driftsucky's Avatar
driftsucky
Originally Posted by skoke70
Ok, I might have ruined my rim according to the tire tech at sears? Going to have it looked at rim repair shop.
My current set up is varrstoen ES3 19x9.5 +22 offset front (245/35/19 tires)
the rears are 19x10.5 +20 offset with 275/35/19" tires.
Called Varrstoen for a replacement and they told me that the won't be getting any of the 19x9.5 +22 offset for a long time if ever? Sounds like they might be discontinued? They do have 19x9.5 +12 on sale, so i could buy a set.
My Q is, how funny Would it look to have +12 offset in the front with +20 offset in the rear? would I rub with 245/35/19 tires?
Thanks
+12 is fine.
As far as its appearance, I'm not sure if you know how insignificant of an amount 8mm is, but it will look fine.
How did you ruin your rim and why are you taking your car to SEARS???!!! Seriously, what the ****. Details.
Old Nov 21, 2013 | 04:41 PM
  #1644
Trevor Hebert's Avatar
Trevor Hebert
We need to get VarrsToen to create black stickers in the 6" and 9".
I would love to put them on some hyperblack wheels. I have emailed them already, and they said they would consider it. Im sure if enough of us gave the idea they would do it!
Old Nov 22, 2013 | 08:25 AM
  #1645
skoke70's Avatar
skoke70
Originally Posted by driftsucky
+12 is fine.
I hit a pot hole! (crappy roads in Nj) I bought the tires at sears (great deal) I also bought the road hazzard warrenty which is a must here in NJ, so I'm getting a new tire for $22. The rim is "out of round" with a bent lip. I'm going to take it to a rim repair specialist and see if they can fix it.
Old Nov 22, 2013 | 01:32 PM
  #1646
beezbo's Avatar
beezbo
Love my 'stoens'
ES3 18x9.5f 18x10.5r
245/35 275/35
+12 +15
Old Nov 22, 2013 | 04:16 PM
  #1647
DrummerGirl's Avatar
DrummerGirl
245/35/19 Front's
275/35/19 Rears
Hankook Ventus V12's, Lowered on Eibach pro springs with SPC camber arms
No fender roll.
Old Nov 26, 2013 | 12:54 PM
  #1648
Mati350z's Avatar
Mati350z
Default help needed!
i'm about to purchase the following for my 08 350z
varrstoen es2
front 19x9.5 +12
rear 19x11 +15
with 245/35 275/35 tires
my question is...I know i will have to roll my fenders but do i have to get a camber kit?
thanks!
Old Nov 26, 2013 | 01:26 PM
  #1649
Neeko94's Avatar
Neeko94
varrstoen es2
front 19x9.5 +12
rear 19x11 +15
thanks!
gunna need wider tires than that for the rear.
and yeah get a kit.
unless you dont mind getting tires every few thousand miles .. hah
Old Nov 26, 2013 | 01:59 PM
  #1650
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
varrstoen es2
front 19x9.5 +12
rear 19x11 +15
thanks!
If you roll your fenders flat you may be able to get away with not buying camber arms on a proper alignment. It will be close though.
Old Nov 26, 2013 | 03:11 PM
  #1651
Mati350z's Avatar
Mati350z
and yeah get a kit.
Even at stock height? I'm not planning on dropping it just yet
Old Nov 27, 2013 | 03:52 AM
  #1652
DrummerGirl
Honestly camber arms aren't that expensive. Do you ever plan on lowering your car? If there's even a chance down the road that you're going to lower it, then I say you should get the camber arms while you're working on all that stuff anyways. Unless you're planning on saving until you get some coilovers, it would make more sense to just wait until you have springs and just throw it all on at once.
But if you're waiting coilovers then (from what I understand) camber arms aren't ABSOLUTELY necessary for stock height but they won't do any harm.
Old Nov 27, 2013 | 10:53 AM
  #1653
Mati350z's Avatar
Mati350z
thank you guys for all your help..just placed an order for...
Varrstoen ES2
19x9.5 +12
19x10.5 +12
aspecwheels having a 15% special for black friday!
Old Nov 27, 2013 | 03:39 PM
  #1654
Mati350z's Avatar
Mati350z
can anyone recommend a camber kit? i have no idea which one to get
Old Nov 27, 2013 | 04:33 PM
  #1655
Bmurray350z
SPL, SPC, Kinetix, etc... Stay away from Ichiba, Godspeed, and those other ebay brands
Old Nov 27, 2013 | 06:01 PM
  #1656
nofrey's Avatar
nofrey
I have godspeed camber kits there garbage but lasted me 3.5 years so far. I plan to get stance camber kits to mach my stance toe arms and coilovers.
Old Dec 3, 2013 | 11:18 AM
  #1657
mg23's Avatar
mg23
Thinking about picking up a set of 18x9.5 +22 ES1's. Anyone have any input on this, I don't know jack about wheels and it would be on stock height z for now.
Thanks
Old Dec 3, 2013 | 12:27 PM
  #1658
Bmurray350z
It won't look bad. may need some 10-15mm spacers for the rear.. assuming you'll get proper sized tires
Old Dec 3, 2013 | 01:33 PM
  #1659
mg23's Avatar
mg23
225-40 in the front and 235-40 in the rear is what the wheels come with
Old Dec 10, 2013 | 09:59 AM
  #1660
frocker93's Avatar
frocker93
225/45 front and 245/45 rear is stock. For a 9.5 wide wheel you can get 255/40 front and 275/40 rears. Fronts will have a small stretch and rears will be pretty flush with the lip, maybe a little meaty.
