Varrstoen Wheels Thread
Old Apr 2, 2015 | 11:42 AM
  #1861
travlee's Avatar
travlee
Master
i would worry about the +12 up front. you will definitely have to have camber
Old Apr 2, 2015 | 11:58 AM
  #1862
chuckbennett81's Avatar
chuckbennett81
Damn I wasn't planning on running camber. Even if I don't lower it, it still has to be cambered for sure? Would a +22 offset in the front be better?
Old Apr 2, 2015 | 12:01 PM
  #1863
travlee's Avatar
travlee
Master
i had a 18x9.5+23 on the front... very little camber and with a 255/40 tire i was rubbing on one of the fender liner screws
Old Apr 2, 2015 | 12:06 PM
  #1864
chuckbennett81
I was planning on going with a 245/35/19 tires size in the front which is less beefy then 255/40. idk if that would make much of a difference
Old Apr 2, 2015 | 12:36 PM
  #1865
chuckbennett81
Originally Posted by VarrsToen
Josh's 04' 350z
19x9.5/10.5 +12
245/275/35 tires
Just ordered these in the same size and same offset For my z. Was wondering what fender rolling and cambering will need to be done
Old Apr 8, 2015 | 05:14 PM
  #1866
ghost116's Avatar
ghost116
From reading all previous posts fender roll probably in order of u lower it
Old Apr 8, 2015 | 05:17 PM
  #1867
travlee's Avatar
travlee
Master
Originally Posted by chuckbennett81
Just order these in the same size and same offset For my z. Was wonder what fender rolling and cambering will need to be done
definitely a roll, and almost positive you will need camber in the front and rear
Old Apr 15, 2015 | 03:01 PM
  #1868
chuckbennett81
Originally Posted by FastWhiteZ
Varrstoen 2.2.2
19x9.5 +12
19x10.5 +12
245/35/19
275/35/19
Did you need to roll the front fenders? ?
Originally Posted by RedLine_ZR
never posted here in the varrstoen thread so here you go
19x9.5 +12
19x10.5 +7 (5mm spacer)
Did the front fenders need to be rolled?
Originally Posted by Koll
Varrstoen 2.2.2
19x9.5 +12
19x10.5 +12
Falken FK453
245/35/19
275/35/19
Did front fenders need to be rolled??
Old Apr 16, 2015 | 07:10 AM
  #1869
Bmurray350z's Avatar
Bmurray350z
Front fenders are rolled from the factory.
Old Apr 18, 2015 | 06:00 AM
  #1870
350Z.'s Avatar
350Z.
guys i have a question:
I found Varrstoen ES 2 19'' black by $1,200 in eBay and in the official website for Varrstoen the price around $ 236 ???
how much the right price and why there are different costs ?
Old Apr 25, 2015 | 09:29 AM
  #1871
medic165's Avatar
medic165
^^Just avoid the hassle and buy through our Varrstoen vendors here. Good luck.
Old Apr 25, 2015 | 09:33 AM
  #1872
medic165's Avatar
medic165
That's what I was thinking 245/35/19 and 275/35/19 but I would deff have to roll the fenders right? And how much do you think I will be able to drop it?
At stock form, you do NOT have to roll the fenders I had the same offsets +12, and 245/275.......now, if u gonna lower it...dunno
Old Apr 25, 2015 | 08:47 PM
  #1873
TACam2's Avatar
TACam2
Originally Posted by kbailey91
got these a couple weeks ago... just so happen to call for a price, they just off loaded them from the truck, so I bought them... first set out the door.
What front bumper is this?
Old May 24, 2015 | 03:48 PM
  #1874
blaac350z's Avatar
blaac350z
Default HELP! new wheels for 350z track
Hello, I am new to the forums but I am currently looking to purchase a set of Varrenstoen ES6 wheels for 03 track 350z. question is, would the setup work?
clear brembo calipers etc. thanks!
the specs of the ES6 are 9.5" 22/5x/114.3/73.1
11" 25/5x114.3/73.1
Old May 24, 2015 | 04:49 PM
  #1875
travlee's Avatar
travlee
Master
you left out several key things.... what is wheel diameter, what size tires are you planning on running.... etc etc etc
Old May 24, 2015 | 04:57 PM
  #1876
SR71's Avatar
SR71
Lead Super Moderator
Maybe just maybe you could try searching this thread.
Old May 24, 2015 | 05:07 PM
  #1877
travlee's Avatar
travlee
Master
but that makes too much sense
Old May 30, 2015 | 09:28 AM
  #1878
Cookiezor's Avatar
Cookiezor
anybody ran es2 11'' et 25 on the FRONT???
thinking of getting a set of 11's for all four. wondering if anyone done it....., if 11 dont fit then i ll go with 9.5 front 11 rear 12/15 offset with 245/275 . that should not rub on stock susp, but dont know tho, hesitant to pull the triggaaaaa
Old May 31, 2015 | 12:59 PM
  #1879
Canada_Z's Avatar
Canada_Z
11" will more than likely rub up front. I ran 19x10 et15 front and 19x11 et15 rear with 245/35 and 275/35 with no issue.
Old May 31, 2015 | 05:49 PM
  #1880
Cookiezor's Avatar
Cookiezor
wow, 11s on the back with et 15 does not rub?? i did not know that! u did not even have to roll the fenders??? the reason why i'm amazed is bc i made a typo putting 15, it was sopose to be 25 for the rear
