Will this offset from a vendor work?
Old Sep 29, 2010 | 08:41 AM
nismofreak1208's Avatar
nismofreak1208
Default Will this offset from a vendor work?
I was told that the following offset, 19x9.5et15+19x11et15, will give the most flush fitment without rolling the fenders, I just wanted to see if anyone can chime in on this and if there is another offset for a flush fitment, could you pm me the details so that i can forward to the vendor? thanks!
Old Sep 29, 2010 | 09:25 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Are you lowered?
Old Sep 29, 2010 | 09:50 AM
06g35meister's Avatar
06g35meister
you will be rolling your fenders if you put anything over a 265 on that rear, and that will be STRETCHED!
Old Sep 29, 2010 | 09:59 AM
nismofreak1208
The Z will be lowered, haven't quite picked how low yet but no more than 1 inch lower than stock. It'll be sitting on HKS hypermax III sport coilovers
So this means i'm pretty screwed then using this offset? I was trying to achieve a look similar to the venaci 370Z with their "spirit" rim line.
Old Sep 29, 2010 | 10:06 AM
AdvanZ33's Avatar
AdvanZ33
The fronts should be fine. Keep in mind the rears will poke out 27.7mm past your stock Nismo wheels but you will gain more negative camber the more you lower it. Nevertheless, you should roll your fenders.
Old Sep 29, 2010 | 10:14 AM
nismofreak1208
I see, what sizes can I safely go with then while managing to obtain an agressive stance without rolling, i'm against rolling unless I have no way around the issue.
Old Sep 29, 2010 | 10:17 AM
AdvanZ33's Avatar
AdvanZ33
I would ask around in the aggressive wheels threads. 19x10.5+22 in the rear seems to be the popular choice.
Old Sep 29, 2010 | 10:23 AM
nismofreak1208
ok, thanks!
Old Sep 29, 2010 | 12:24 PM
scotts300's Avatar
scotts300
Depends on what tires you get. Anyone else is simply guessing or assuming.
Old Sep 29, 2010 | 01:16 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Just like Scott said, flushness (or lack thereof) has as much to do with your exact tire choice (not just the size, as that tells you nothing...you need to pick an exact tire) as it does your wheel choice...the wheel doesn't ride on the ground after all. It all operates as a unit, none of it is in a vacuum.
No amount of rear camber is going to prevent that wheel from rubbing on a stock rear 1/4panel car, regardless of tire size. You will need to roll them (heavily). Not a big deal, just has to be planned for.
Old Sep 29, 2010 | 02:19 PM
nismofreak1208
Ah i see, after doing some searching, I managed to find a member who was running the size rims I would like to run using the sizes 255/35/19 and 285/35/19, the only difference i noticed was he had a +24 front and +17 rear where as the vendor qouted me a +15 front and back. The member stated he needed those offsets to clear BBK's and since I am planning to upgrade to 14" BBK's, should I inform the vendor that I need to change my offsets? I've already calculated rolling the fenders now, there's no other way to get the wheels I want without it, just hoping that it turns out well.
Old Sep 29, 2010 | 03:38 PM
Z1 Performance
Former Sponsor
Again sizes are meaningless, you need to choose a tire
Brakes - every kit has different clearances it's not one offset clears all
Old Sep 29, 2010 | 03:45 PM
calin's Avatar
calin
The rear is 19x11 +13 with a 275/35 tire
Old Sep 29, 2010 | 05:29 PM
nismofreak1208
The tires will be Hankook Ventus V12 evo K110 and the BBK that i'm leaning towards is either AP racing or the Alliance BBK 14" 6p front and 13" 4p rear combo for either BBK.\
Calin, nice setup, I assume your fenders are rolled?
Oh if anyone was wondering why I wanted somewat fat tires, its cause i'm looking to still track these and don't wanna go too fat, so far everyone says 285's are perfect in the back but is 255 a tad too big? should i go 245?
Old Sep 29, 2010 | 07:41 PM
scotts300's Avatar
scotts300
If you want to track a brand new (expensive) set of 19" wheels, you have your priorities a little mixed up. Track wheels, over time, get beat up, and 19" tires are expensive. I'd get an extra set of 17s or 18s and call it a day. Track wheels are also best, in my opinion, to have conservative offsets (i.e. high offsets, not squeezing the wheel so that it just barely clears).
Old Sep 29, 2010 | 07:46 PM
sry110's Avatar
sry110
nevermind EDIT
Old Sep 30, 2010 | 04:50 AM
nismofreak1208
alright, thanks for the input guys, i'ma just keep my rays with the re-11s and use those for track
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
