Wheel and tire size assistance... feathering
Old Dec 26, 2010 | 10:26 AM
mikeyfosure1's Avatar
mikeyfosure1
Default Wheel and tire size assistance... feathering
I have an 03 Touring with the stock 18" wheels. I'm in need of tires as I believe feathering has taken its toll. I heard that is common on the 03 model, what is the best solution? Just alignment and camber adjustment?
As for new wheels and tires I am debating on just getting new ones for the 18s vs. buying new 17s.
If I keep stock 18" wheels, what are suggestive sizes for front and rear? They are 225/45 Front and 245/45 Rear currently. I desire wider Rear tires to reduce wheel spin on hard acceleration and when powerband kicks in. I like treadwear to be 300+ and need better handling during precipitation. Any brand suggestions?
On the other hand, if I go with 17s what rim width staggering can I get by with while still achieving the goals mentioned above? Plus, I do not want effect under/oversteer as I know staggering can.
Thanks
Old Dec 26, 2010 | 03:39 PM
Impossible to tell without photos.
Old Dec 26, 2010 | 04:08 PM
terrasmak's Avatar
If you want wide rear tires you need wide rear wheels, if you want sticky tires you need something in the 200 treadwear area.
You're kind stuck with 245's , but you can throw 245/40 up front to make the car handle better
Old Dec 30, 2010 | 11:22 AM
0350Zz's Avatar
0350Zz
If I keep stock 18" wheels, what are suggestive sizes for front and rear? They are 225/45 Front and 245/45 Rear currently. I desire wider Rear tires to reduce wheel hop on semi-hard acceleration and when powerband kicks in. Basically, I want to reduce wheel spin. I like treadwear to be 300+ and need better handling during precipitation. Any brand suggestions?
Thanks
im kind of in the same boat. When i got my 03, it had pretty bad tires and i currently have it garaged during the bad weather due to all the salt on the road but when i was looking into buying an 03 i saw a thread dedicated to this issue...i was wondering if anyone had a link?(to the post on multiple proposed fixes on the 03/04 alignment issue)
Old Dec 30, 2010 | 11:44 AM
Old Dec 31, 2010 | 09:29 AM
0350Zz's Avatar
0350Zz
Originally Posted by davidv
Thank You!
Old Jan 2, 2011 | 01:58 PM
mikeyfosure1
So it looks like I'm keeping the stock 18s with original tire measurements after assessing my wants and driving style. I am still wanting treadwear at 300. I have decided to upgrade suspension to reduce wheel hop. I'm thinking gr2s unless better suggestions?
Now my main concern is traction during wet conditions. Any brand suggestions?
Sent from my HTC incredible.
Old Jan 2, 2011 | 04:36 PM
Before buying tires check these test results: https://my350z.com/forum/showthread....ighlight=tires
Old Jan 3, 2011 | 12:10 PM
mikeyfosure1
What if I went with 245/45 all around? Then I could rotate front to rear, I would hate to buy 2 different sizes that close to each other... just wondering.
For now, I have chosen:
Continental
ExtremeContact DWS
If anyone knows where to buy for best price?? Enlighten me! Thanks
Old Jan 3, 2011 | 02:14 PM
Continental
ExtremeContact DWS
Do you have VDC?
Old Jan 3, 2011 | 03:01 PM
terrasmak's Avatar
Continental
ExtremeContact DWS
Whats wrong with having 2 different sizes. The tires just have to be flipped for rototion, simple. Also you will typically go thru 2 sets of rear per set of fronts, no big deal.
Old Jan 3, 2011 | 07:14 PM
mikeyfosure1
Do you have VDC?
Yes. That's the first button I hit after starting the car. Can't kick it with vdc on.
Sent from my HTC Incredible.
Old Jan 3, 2011 | 07:15 PM
mikeyfosure1
nothing at all. I like the stagger.
Old Jan 4, 2011 | 03:34 AM
I suggest you study this thread: https://my350z.com/forum/wheels-and-...read-here.html
burglapfd
Dec 6, 2020 01:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
