GT-V negative offset
Old Mar 1, 2011 | 05:06 PM
ryuchrist's Avatar
ryuchrist
Default GT-V negative offset
was trying to get a GT-V rim. 19X8,5+23 & 10.5-15-5X114,3-245-35-19-275-30-19. do u think this will fit n clear my brembo? will it rub the fender?‏
Old Mar 1, 2011 | 06:14 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Mar 1, 2011 | 06:27 PM
fatboy.yoshi's Avatar
fatboy.yoshi
yes, the 10.5 -15 will clear the brembos...that was one of my first setups...comes with a high pad....and yes it will rub...
Old Mar 1, 2011 | 06:34 PM
microsteve40's Avatar
microsteve40
Know it all
The 275 width tire and the -15 wheel is going to require a massive amount of neg camber if you are lowered at all. And you'll probably still rub, but it'll look mean!
Old Mar 1, 2011 | 06:40 PM
dkmesa350z's Avatar
dkmesa350z
10.5 -15 rear and 8.5 +23 front will look horrendous unless you plan on having a 33mm spacer in the front lol. If that conservative front is all you have to choose from, aim for a 10.5 +24 rear or so. Otherwise, get a low/zero/negative offset 9.5 up front to line up similarly with the rear.
Old Mar 1, 2011 | 06:42 PM
lgear080's Avatar
lgear080
Supra front? Don't get 19x8.5 any offset at all for z
Old Mar 1, 2011 | 06:46 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Unless they are going on this...
Old Mar 1, 2011 | 07:14 PM
theianmcdougall's Avatar
theianmcdougall
fronts, ewww
rears, niceeeee
Old Mar 1, 2011 | 08:29 PM
kemps's Avatar
kemps
There's so many other better looking wheels out there, just sayin..
m_0g
Jun 3, 2021 10:05 AM
seagrasser
Oct 11, 2015 03:27 PM
