grand touring wheels with 305/30?
Old Mar 9, 2011 | 06:06 PM
DanteG35's Avatar
DanteG35
Default grand touring wheels with 305/30?
Hey guys, so I have the Grand Touring wheels 245/40/18 fronts and 265/35/19 rears.
Would it be safe to get 305/30/19 for the rears?
Old Mar 9, 2011 | 06:45 PM
terrasmak's Avatar
What is minimum width for a 305, and how wide is your wheel?
Old Mar 9, 2011 | 07:20 PM
Nexx's Avatar
Nexx
it will buldge a bit on a 10 inch wheel but it will work.
Old Mar 9, 2011 | 07:48 PM
JLS2GOZ's Avatar
JLS2GOZ
It works fine if your not lowered.
Old Mar 9, 2011 | 08:02 PM
omsin523's Avatar
omsin523
I would go 285/35
Old Mar 9, 2011 | 08:09 PM
zerostyle's Avatar
zerostyle
its safe....but it wont look as good...on a 10 inch rear...i say max 295....i put some 295/30's on a ten inch wheel today and it was perfect
Old Mar 10, 2011 | 03:33 AM
What size is the wheel?
Old Mar 10, 2011 | 09:59 AM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Do you mean on the factory/OEM grand touring wheels? or aftermarket wheels?
Old Mar 10, 2011 | 10:13 AM
Kuhan's Avatar
Kuhan
I believe he has 19x9 front and 19x10 rear (Grand Touring wheels). I have 285/35 tire on 19x10 wheel, and the tire is flush with the rim.
So 305 should be no problem considering the +30mm offset, you shouldn't have any issues with the tires rubbing. Like mentioned above, the tires will bulge out a little.
305mm = 12 inches.
Old Mar 10, 2011 | 11:24 AM
SparkleCityHop
Living in 350Z
I'm also 285 on a 19x10 and as you mentioned, the tire is flush with the wheel lip. I'm sure that I could safely run 305 on mine as well.
Old Apr 3, 2011 | 06:11 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
Obadabot
Jun 18, 2023 11:31 PM
