10mm or 15mm spacer on this???
Old May 14, 2011 | 05:28 PM
draco1020x's Avatar
draco1020x
Default 10mm or 15mm spacer on this???
Im looking to bring the rear wheels right out to the fender, but im not sure which size spacer to go with. Would i be better off with a 10mm or a 15mm with fenders rolled? Im not sure if the 15mm will be too much. I thru on a 20mm a saved from my stockys jus to see wut it looked like before i dropped it and it looked crazy (as in not good lol). Im dropped about an inch in the back on Stance GR+ Pros. Im not looking to go too low and lose functionality of the car, i would just like a better stance. Its a G, btw for those of u who are wondering.
PS: Dont tell me to get new wheels
Old May 14, 2011 | 06:11 PM
sry110's Avatar
sry110
Looks like you could fit 15mm in there without rubbing on the fenders (assuming your fenders are rolled). What offset are those wheels?
Old May 14, 2011 | 07:02 PM
Black Z Eddie's Avatar
Black Z Eddie
Measure the gap:
Old May 14, 2011 | 08:13 PM
scotts300's Avatar
scotts300
Anyone making a suggestion without asking wheel width and offset is merely guessing, which you could do on your own. Eddie hit the nail on the head assuming we don't know the width and offset. Take a wheel off, and look inside of it.
Old May 15, 2011 | 11:00 AM
draco1020x's Avatar
draco1020x
Oh Sorry guys, I completely forgot to put them. Rears are +20 and fronts are +15
Old May 15, 2011 | 03:16 PM
Kuhan's Avatar
Kuhan
^What are the wheel widths? 20x9 and 20x10?
Old May 15, 2011 | 06:27 PM
draco1020x's Avatar
draco1020x
Yes
Old May 15, 2011 | 08:21 PM
marques1's Avatar
marques1
never mind, lol.
Old May 16, 2011 | 06:18 AM
sry110's Avatar
sry110
What are the tire widths?
Old May 16, 2011 | 07:36 AM
draco1020x's Avatar
draco1020x
Originally Posted by sry110
what are the tire widths?
275/30
Old May 16, 2011 | 09:40 AM
sry110's Avatar
sry110
Originally Posted by draco1020x
275/30
FWIW On my Z I am running 285's at +12 offset in the rear with fenders rolled and I have plent of clearance. You can definitely fit a 10mm spacer, an I imagine a 15mm would work especially if the fenders are rolled tight.
Edit: also I am within oem limits for camber.
Old May 16, 2011 | 10:13 AM
marques1's Avatar
marques1
I have this same setup. I just bought 15mm spacers out front and 25mm spacers out back. I'm going with a stretched tire look but we will see how this works soon enough.
Old May 16, 2011 | 10:59 AM
BoomerZ33's Avatar
BoomerZ33
looks like you can squeeze a 15. have you adjusted your camber yet?
Old May 16, 2011 | 03:45 PM
draco1020x's Avatar
draco1020x
Nope, thats next. Im sure im a lil negative. Do ya think it be safer to run a 10? Idk if the 15 will be too close once the camber gets corrected.
Old May 16, 2011 | 03:58 PM
marques1's Avatar
marques1
This is pre spacers!! Will update the thread after spacers/new tires/rolled fenders and camber setting are dialed in.
Old May 16, 2011 | 05:31 PM
Black Z Eddie
^^ looks good the way it is. But, am curious how it'd look with the changes you're going to make.
Old May 16, 2011 | 07:30 PM
marques1's Avatar
marques1
well, we will find out soon, lol.
Old May 17, 2011 | 07:11 AM
Kuhan's Avatar
Kuhan
Yours
F: 20x9 +15
R: 20x10 +20 with 275/30
Mine
F: 19x9 +22
R: 19x10 +25 with 285/35
I tried a 10mm spacer for the rear, and it fitted pretty flush without rubbing (1 finger gap between the tire and fender). My Z is lowered on Bilstein Pss10 and the fenders are rolled.
Last night, I ordered H&R 10mm and 15mm spacers. I will update once I install the spacers and after gettting an alignment.
Old Aug 19, 2011 | 10:38 PM
laksjd84's Avatar
laksjd84
where is ze update?
Old Aug 22, 2011 | 04:40 PM
PrimeX's Avatar
PrimeX
Update! I'm trying to decide the same thing and yours looks similar to my fronts.
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
FromGtoZ
Sep 20, 2015 03:41 PM
