E Brake, VDC and Slip sign on
Old May 28, 2011 | 05:44 PM
kihun's Avatar
kihun
Default E Brake, VDC and Slip sign on
I searched and found one article but he didn't seem like he found an answer.. My car is very low to the ground and every time I come home, my bottom of my car grinds through speed bump. two weeks ago, my brake sign, vdc and slip sign started coming on after couple of miles of driving and now every time I turn on my vehicle, three lights come on instantly.
does anybody know this issue? it saids wheel speed sensor on the other thread but he didn't respond afterwards. let me know if you have same issue.
Old May 28, 2011 | 06:02 PM
terrasmak's Avatar
Brake fluid? Is it low?
Old May 28, 2011 | 06:30 PM
TWISM's Avatar
TWISM
mine was doing the same and it ended up being the clutch fluid
Old May 28, 2011 | 06:41 PM
DB350's Avatar
DB350
mine did that and at first it was the brake fluid, then once i changed the pads it fixed it.
Old Jun 2, 2011 | 11:50 AM
kihun's Avatar
kihun
i guess i'll go to shop tomorrow and see whats up. thanks gents.
Old Jun 2, 2011 | 11:57 AM
FATPUBUS's Avatar
FATPUBUS
You can just pop off the brake cover and look at the brake fluid resivoir and tell if it is low or not. if it is, it prolly meant your pads are wore out and you need new ones. Just top it off till you swap pads out.
loudtoyz
Apr 6, 2023 04:52 AM
samansharif
Sep 25, 2015 12:31 PM
