Lowered 350z drivers - do you scrape?
Old Dec 8, 2003 | 09:09 PM
___DJK___'s Avatar
___DJK___
Question Lowered 350z drivers - do you scrape?
I am getting a set of HKS LS+ coilovers installed this week and recently realized I might not be able to park in my parking garage at work because of the speed bumps. Do any of you with dropped Zs notice you are scraping your cars on speed bumps or driveways which you could previously take when at the stock height?
If i end up scraping, im gonna head over to my work on a sunday with a jackhammer and "massage" the speed bumps a little
Old Dec 8, 2003 | 09:33 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
I scrape my stock height z in my apartment complex...
IM moving before I lower mine...
Old Dec 9, 2003 | 04:14 AM
westpak's Avatar
westpak
SFZCC
Lowered with Eibachs and no additional issues from before lowering, I am just careful in parking spots and if a steep ramp. but otherwise no issues with speedbumps.
Old Dec 9, 2003 | 07:44 AM
Mr Twisted's Avatar
Mr Twisted
I've lowered my car to just barely claear a 2x4 on end (3 1/2") . Most speed bumps are ok but there are some high ones out there. Now drive ways are a problem. I had to get driveway plates to span my own driveway and gutters. Steel Plates 16'"wide 48"long 3/4"thick and weigh a ton (didn't want anyone stealing them). Even with 3/4 " the plate flexes a 1/ 4" inch when the car goes on it,
Its eazy to up most steep driveways at a angle it's getting out. Ive got a lip too.
I carry 2 - 2x6x10" pieces of wood in the spare wheel well just in case ( bridging gutters)
Old Dec 9, 2003 | 07:50 AM
Moroccan_Mole's Avatar
Moroccan_Mole
i haven't scraped at all since lowering the car and adding the body kit, and my car is LOW, probably 4-5" from the ground
Old Dec 9, 2003 | 07:58 AM
Mr Twisted's Avatar
Mr Twisted
Look under the car Exhaust flanges are the lowest part of the car. On my car lip sits 5", bumper sides and mud guards sit 4" and exhaust flanges sit at 3 1/2 ins from the ground.
Old Dec 9, 2003 | 12:12 PM
DruDragzOn's Avatar
DruDragzOn
My car is lowered with Eibachs. I haven't had problems scraping. I just go really slow on the deep ramps. When I do scrape, it's usually the backside, probably my aftermarket exhaust scraping. I'm getting a body kit soon. I'm probably not installing it after winter. I hope I won't have too much problem.
Old Dec 9, 2003 | 02:16 PM
Topics II's Avatar
Topics II
I can barely fit the front of my shoe under my Z. Im so cool!!!
Old Dec 9, 2003 | 06:38 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I have Eibach, and when I go over high speed bumps in shopping center, it scraps.... I have to go really really slow, then it would be okay. Just need to drive slow when going up driveway, ramps, etc..
Old Dec 9, 2003 | 07:09 PM
___DJK___'s Avatar
___DJK___
Im used to going super slow over speed bumps but Ill probably have to go even slower. I hate those impatient minvan drivers that practically touch your bumper behind you while you are going slow over the speed bumps! Damn soccer moms cant be in that much of a hurry!
Old Dec 10, 2003 | 02:39 AM
ZRAYGO's Avatar
ZRAYGO
HERES A SOLUTION. I BOUGHT THE TEIN COILOVER KIT WITH THE EDFC. I AM HAVING IT INSTALLED IN ABOUT A MONTH WHEN MY INGS KIT GETS HERE FROM JAPAN. WITH THE EDFC, YOU CAN RAISE AND LOWER THE CAR...EVAN DURING DRIVING.
Old Dec 10, 2003 | 05:07 AM
MY350Z.COM's Avatar
The EDFC adjusts the damping not the height.
Hence the name "Electronic Damping Force Controller"
Old Dec 10, 2003 | 05:10 PM
jeff's Avatar
jeff
I scraped a couple of times at the end of my driveway. The next time the car was up on a lift I found (as Mr. Twisted pointed out) the the exhaust flange at the bottom of the cats was the lowest point of the car. There are also some points on these flanges, I just had the shop grind the points down a bit and I haven't scraped since.
Old Dec 10, 2003 | 06:43 PM
Beaker02's Avatar
Beaker02
Ditto
Old Dec 10, 2003 | 07:35 PM
iLLestJrz's Avatar
iLLestJrz
I just lowered my Z with S-Tune. I'm alright, I can get up my driveway just fine. Actually it feels same stock height.
Old Dec 10, 2003 | 10:07 PM
___DJK___'s Avatar
___DJK___
S Tune isnt much of a drop though is it? like 20mm or something?
Old Dec 11, 2003 | 12:43 PM
Beaker02's Avatar
Beaker02
Ditto.
Old Dec 12, 2003 | 06:40 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
You are kidding right? you must have the Tein Hydro Shocks with remote control..
Old Dec 12, 2003 | 07:49 PM
big-al's Avatar
big-al
hey, sounds like my setup(sittin about maybe...2.5" off the ground) except mines doesn't raises and lower automatically.
James1990
Dec 16, 2015 08:57 PM
Vigman
Nov 17, 2015 04:34 AM
irishguy0224
Sep 22, 2015 06:57 PM
_koubie_
Sep 20, 2015 06:34 PM
CJs_Z33
Sep 18, 2015 12:06 PM
