Using 17-inch wheels from a 2005 on a 2007
Old Dec 11, 2011 | 02:27 PM
mike212's Avatar
mike212
Default Using 17-inch wheels from a 2005 on a 2007
I currently have an 07 with 18-inch touring v2 wheels (http://i44.tinypic.com/2r43dht.jpg).
Will 17-inch wheels (http://i42.tinypic.com/msgewy.jpg) be a direct fit if I want to run them as a dedicated set for winter tires?
Thanks!
Old Dec 11, 2011 | 02:34 PM
DavesZ#3's Avatar
DavesZ#3
Yes, they will fit
Old Dec 11, 2011 | 02:53 PM
Deteria's Avatar
Deteria
why would they not fit if they came w/ the Z back in 2003?
Old Dec 11, 2011 | 02:58 PM
KornerCarver's Avatar
KornerCarver
Because in 2006, Nissan went to a larger diameter brake rotor. It is a valid question.
Old Dec 11, 2011 | 04:11 PM
17 inch wheels and snow tires is a popular subject. Remember you are getting two 7.5 inch wheels and two 8.0 inch wheels. Keep the same size wheels on the same axle.
Old Dec 11, 2011 | 04:52 PM
mike212's Avatar
mike212
Is there a way to tell from the rim itself? My other option is going with the current tires on em.
There are two rims that have 235/50/17 tires on at the moment. I'm assuming these will only fit the rear axle. The other two rims have 225/50/17 tires on, and these should fit the front. Did I figure this out right?
Old Dec 11, 2011 | 05:14 PM
Don't recall if specs are stamped on the wheel.
Front: 225/50/17
Rear: 235/50/17
is OK. Question is do you have VDC?
Old Dec 11, 2011 | 05:49 PM
mike212's Avatar
mike212
Front: 225/50/17
Rear: 235/50/17
I do have VDC. My 07 is a touring. I kept the front at 225/50/17 but I'm having 225/55/17's mounted on the rear axle instead. I was told by tirerack that this combo (225/55/17 rears and 225/50/17 fronts) would be within specs for VDC and SLIP to work properly. I was more concerned with making sure that the 05 rim will physically fit on my 07.
Old Dec 11, 2011 | 07:19 PM
terrasmak's Avatar
The OEM 17 inch sizes or what you just posted will work great with VDC
Old Dec 12, 2011 | 03:02 AM
DavesZ#3's Avatar
DavesZ#3
It doesn't matter, as stated in the Top 100 Questions thread, they will even fit over Brembos.
Old Dec 12, 2011 | 04:24 AM
mike212's Avatar
mike212
Thanks for your help
Old Dec 12, 2011 | 05:49 PM
Spike100's Avatar
Spike100
Mike, I think your questions are answered, but just as a review.
1) The 17” wheels you ask about will fit your car.
2) 225/50/17 Front, and 225/55/17 Rear is ideal and works perfectly with VDC.
You're good to go with the selections you are considering.
--Spike
